f/s Bseries All motor stuff and other stuff cheap MUST SELL
B16 Head- milder Ported and Polished by z-tech. Stock type-r valves valves, Supertech Spring and retainers w/valve job. USED $600
Skunk-2 throttle body- 70mm no tps or map. USED $130
RC 310cc injectors- USED $160
Greddy sp2 for dc2- USED $150
Endyn B-series 81.5mm B18b Roller Wave pistons- N/A high compression compression/height 1.185 comes with pins and lock needs rings, needs rings under 5000 miles. USED $150
Eagle ls big bolt-Used $100
Hondata s100 comes with ecu from hondata- $200
ARP-Ls/Vtec Head Studs USED $40
Moroso- Alumi 5.5 quart oil pan with ls pick up used $130
Drive Shaft Shop- B-series Old stage 3 axles don’t need hubs for these. $400 (rated at 600hp)
Hasport- B-series engine, tranny and back mount. Fits EG and DC2 $200
Fidanza-B series Flywheel 12lbs. USED $50
Exedy- B series flywheel 7lbs USED $100
Avid- Traction bars for EG and DC2 $200 USED
pm for details and pics
Edited prices lower to move please don't pm me if you are trying to low ball me by an extreme amount Thanks
I will take ur throttlebody and ur flywheel Fidanza for $160(626-679-6406)B16 Head- milder Ported and Polished by z-tech. Stock type-r valves valves, Supertech Spring and retainers w/valve job. USED $600
Peak-Performance B-series vtec cams with Peak cam gears- Low miles looks to be less than 5000 miles put on them. USED $300
Specs on cams: Intake: Duration: 255° @ 0.05in Lift: .496in
Exhaust: Duration: 256° @ 0.05in Lift: .494in
Edelbrock Victor-X intake manifold for B16/B18c5 4764- Used Comes with Hondata gasket. USED $250
BDL B-series fuel rail- bronze. USED $75
RC 310cc injectors- USED $200
Rage B-series Tri-y header-no dents not smashed on bottom great condition. USED $400 or $425 with Omni test pipe cut to replace cat.
Fluidampr- For B-series, street version-a/c p/s. USED $200
AEM fuel pressure reg.- Red $50
I would highly suggest not purchasing from this user.
I sent payment for the Fluidampr on January 30th and have got nothing in response to PM's or IM messages on AIM as to where the unit is or a tracking number.
I was able to contact him on AIM once where he told me due to his work and school schedule it was hard for him to get the part shipped. Then, he told me he couldn't get the damper off the crank, so he had to drop it off at the machine shop to have them remove it. And due to the troubles it has caused me, he offered to send a spare VTEC solenoid he had.
I'm still waiting on a tracking # or just a response from him to my PM's.
Please do the right thing Bret Read.
Buyers Beware. I'm filing a claim through PayPal to get my money back for the engine dampener I bought from him.
I did get my parts. Other than limited communication due to his schedule this was an "ok" at best transaction.
