Need help with a 98 si front lip
Old Dec 9, 2008 | 07:42 PM
4serioferio's Avatar
Icon2 Need help with a 98 si front lip
I have never put on a lip before, so I am quite the noob.
I assumed that there would be 4-6 holes to put some screws into. I guess I was wrong?
There were no holes on the lip, I had to drill them out myself where small indents indicated. Which I was told is not uncommon.
But I don't see any place to mount screws into on my front bumper, and the lip is sorta warped and seems like it would never fit flush. What do I use to fasten it on?
What am I doing!?
Help is much appreciated. Thanks.
Old Dec 9, 2008 | 07:45 PM
Little_Nolan's Avatar
What kind of lip is this.... they didnt make 98' USDM si lips?
Old Dec 9, 2008 | 07:48 PM
geneeunit's Avatar
yeah, there is not 98' Si..
only 99-00 and if you got a 99-00 lip it isn't going to fit on your 96-98 front end. sorry pal.
Old Dec 9, 2008 | 07:49 PM
Uh... thats the problem. It was a birthday present from a friend. He said it was si. Thats all. And I dont know my stuff well enough to be able to identify it.
Old Dec 9, 2008 | 07:53 PM
You could post a pic up.. is it abs plastic, CF, OEM painted plastic?
From what you described it is a off brand "Ebay" type abs plastic front lip... Chances are you are just going to have to screw it to the underside and the sides/rear where is wraps around the bumper.
As to the warping; this is common for these types of lips, hopefully it wont be noticable when you bolt it up.
Best of luck.. PM me if you need help or pic assistence
Old Dec 9, 2008 | 07:54 PM
Ok. Called him. And he said he knows it fits my car. No doubt. and he thinks its SiR.
Old Dec 9, 2008 | 08:08 PM
YoungMoneySi's Avatar
if you had to drill holes onto the lip then it is not OEM.
all OEM parts fit perfectly without any modification needed cuz the car was built to add on the extra OEM parts
Old Dec 9, 2008 | 08:19 PM
Warhawk's Avatar
Well if you need to re-shape it slightly I heard using a heat gun can help bend it a little to make it fit. My lip stuck out quite a bit on the sides I just put 2 screws on each end.
Old Dec 9, 2008 | 08:22 PM
teamworxek9's Avatar
if its a sir lip it should bolt right up mine did. it is so purdy.
Old Dec 9, 2008 | 10:25 PM
NOFX's Avatar
H-T White Ops
Is it matte black and mounts under the front bumper? This is the SiR front lip.
http://i43.photobucket.com/albums/e3...k/100_1412.jpg
http://www.inlinefour.com/jdmsirekfron.html
Old Dec 9, 2008 | 10:35 PM
Ha. I put it on before I even read this. It bolted on pretty well, has some small gaps. But the ends stuck out, so I just put 2 screws in as well.
Darkint3gra
10
Feb 23, 2011 07:51 PM
BoostnEK6206
16
Mar 20, 2008 07:50 AM
slikz714
Jul 4, 2005 08:43 AM
dungy
Jul 29, 2002 09:43 AM
vinceman
Jul 18, 2002 07:17 PM
