Sea Foam?
Both Gm TCC and Sea Foam are both decarboning agents, and their main use is the removal of carbon deposits in both the intake tract and the cylinders' themselves. I also use GM TCC to release gummed up piston rings and sticking valves.
Both are normally introduced to the engine thru a disconnected vacuum hose, or thru vacated spark plug holes - depending on your intended use.
P
P
i used to have a del sol and used seafoam for the first time at 180k miles. I gained a couple mpg afterwards and noticed it running a bit smoother. I sold it with around 200k on it and it still had no problems.
I have heard of other people having leaks after using it though. Some of the carbon deposits in the engine can actually be clogging up holes that you aren't aware of.
As mentioned in the post below yours, sometimes those carbon deposits can be sealing up leaks from over time with leaky rubber gaskets and what not.
Toss in a can of Sea Foam and it'll eat all that away leaving you with some thinned out or non-existant gaskets.
hxtasy
Jan 30, 2006 08:33 PM
