92 lx 4dr wit 99 ls swap f/s only need gone today
its a 92 lx 4dr navy blue the car is pretty clean the rust that wa there was fixed by the previous owner has a full 99 ls swap has a fuel pessure regulator
cam seal dc sport 1 peiece header has a slight exhuast leak from where they took out the cat-converter and welded the pipe has a short shifter not installed yet car was auto but converted stick all thats need s the auto to manual mount car is sittin on coilovers wit kyb adjustable struts u can adjust the stiffness of the ride also is comin wit the 14in konig wheels 2 of the tire have pretty bad camber wear and is also comin wit 2 14in steelies wit fresh tires also i started the wire tuck removed all the a/c lines all that need to be removed is the powersteering lines and is coming wit a uncut obd1 ls engine harness looking to get 1500 obo hit me up wit ur offers cause need gone today but dont try and lowball me hit me up 856 213-3185 Ricky also has arp head studs and a type r water pump
