jun iii cams question
Old Dec 9, 2008 | 04:47 PM
gsrjdm00's Avatar
Default jun iii cams question
hey guys heres what i got stock itr motor, with 3" intake, 98 spec itr header with 2.5 test pipe, was thinking about to put in jun iii cams, my question is what kind of power will i be making with that setup and also is it possible to run the cams with stock valve train
Old Dec 9, 2008 | 04:54 PM
joeyrtype2k's Avatar
go with the skunk2 pro 1's u will need springs and retainers for skunk2 or the jun's
Old Dec 9, 2008 | 06:29 PM
LobeSex's Avatar
way cheaper than jun...and way cheaper than skunk2...look into thim i got the stage 3's for my h23
http://www.crower.com/cat/import/hon...s/b_vtec.shtml
Old Dec 9, 2008 | 06:33 PM
Tomcat's Avatar
In order to make some power with the JUN III's, you will need higher compression, (at least 11.5:1, IMHO), adjustable cam gears, some head/IM work, stand-alone engine management, bigger injectors (at least 310), adjustable FPR, JUN valve springs, some brand of Ti retainers, higher flow header, full 2.5" exhaust, tuning. These are pretty much the minimum requirements for making power with the JUN III's.
What you make on a dynamometer would vary depending on the type and make of dynamometer, geographic location, whether or not atmospheric correction of the result is used, the condition of your engine, and lastly the bolt-ons. Adding after-market intake/header/exhaust might add 10-15whp to what you would otherwise make. Always remember, dynamometers are meant to be used primarily as a tuning aid.
Old Dec 9, 2008 | 06:47 PM
gsrjdm00's Avatar
yea thanks guys, another thing, can i run any cams with stock itr valve train, and still make power should i get rid of the 98 spec headers
Old Dec 9, 2008 | 06:53 PM
LobeSex's Avatar
just stage ones(normally) but they will tell u if aftermarket valvetrain is nessecary
Old Dec 9, 2008 | 07:19 PM
sloEL's Avatar
Do springs/retainers at the same time. Do it right...once.
Old Dec 9, 2008 | 08:05 PM
gsrjdm00's Avatar
is it possible to run spoon cams with stock valve train, or also is it worth to get a krome ecu for a stock itr with bolt on can it make good power
Old Dec 12, 2008 | 01:14 PM
Robs_B18c's Avatar
I made 194whp on a jdm itr, jun3, blox valvesprings and retainers, itr header 4-1, aem 3" intake on neptune via suprdave
Old Dec 15, 2008 | 06:14 AM
mr.lisbon's Avatar
Spoon Sports camshafts are very similar to the ITR camshafts.
I was running them before going to Jun3.
DOnt spend your money on the SP ones
Old Dec 15, 2008 | 09:34 AM
jdmitr's Avatar
Really if you are not going to upgrade everything else (like - springs, retainers etc...) then you are going to get a cam that wont do much at all. My suggestion is if you plan on doing the mods to be able to run the Jun3 cams then get everything else done when you can and build up to it. If you want more horses on a near stock level (not tearing into the motor) while staying NA then there isnt many more worth while horses you can get without stepping up and spending some money.
Old Dec 16, 2008 | 08:32 AM
CW-ITR's Avatar
Default Re: X2
x2
camodeen
Feb 12, 2014 01:20 PM
Junior_7
Jun 6, 2005 09:41 AM
topspeed86
24
Jul 21, 2003 02:23 PM
Grocery Getter R
Jan 31, 2003 04:03 PM
JDMvtecDRAGSTA
Jul 22, 2002 01:21 AM
