JRSC B-series blower pulley boost and belt specs
Old Dec 9, 2008 | 02:29 PM
Cloner's Avatar
Default JRSC B-series blower pulley boost and belt specs
I just bought a JSRC and didnt find all the info I needed in the search engine. I had to look all over the place. Im posting this to help others.
Jackson Racing Pulley Configurations
RUNNING TOO MUCH BOOST OR BOOST WITHOUT PROPER TUNING WILL DAMAGE YOUR
MOTOR USE THIS INFORMATION AT YOUR OWN RISK
Common Crank Pullies
Crank Pulley Inner Diameter Outer Diameter Weight
CRV 6.36"/16.2cm 6.57"/16.57cm 6.6lbs
LS 5.79"/14.7cm 6.00"/15.20cm 6.6lbs
SIR/GSR/ITR 5.38"/13.7cm 5.59"/14.20cm 5.4lbs
Belt Sizes For Pullies
Pulley Stepper Belt
SIR/GSR/ITR N 40315
SIR/GSR/ITR Y 40315
LS N 40330
LS Y 40330
CRV N 40340
CRV Y 40340
4.2 N 40240
4.2 Y 40255
4.0 N 40235
4.0 Y 40250-40255
3.8 N 40230
3.8 Y 40245-40252
Note: 1. To prevent slippage run POLY V belts.
2. Slightly longer belts may be used for better belt wrap on high rpm pulley combinations.
Boost with Common Pulley Combination for B-Series - M62 with VTEC Motor
Engine Size (cc) Crank Stepper Nose Boost (PSI) Blower RPM
1595 (B16A) SIR NO 4.2" 6.9 10888
1595 (B16A) SIR NO 4.0" 7.9 11433
1595 (B16A) SIR NO 3.8" 9.3 12034
1595 (B16A) SIR YES 4.2" 9.7 12195
1595 (B16A) SIR YES 4.0" 11.2 12804
1595 (B16A) SIR YES 3.8" 12.8 13478
1595 (B16A) LS NO 4.2" 8.6 11718
1595 (B16A) LS NO 4.0" 9.9 12304
1595 (B16A) LS NO 3.8" 11.8 12951
1595 (B16A) LS YES 4.2" 12.1 13124
1595 (B16A) LS YES 4.0" 13.5 13780
1595 (B16A) LS YES 3.8" 14.9 14505
1595 (B16A) CRV NO 4.2" 11.6 12871
1595 (B16A) CRV NO 4.0" 13.0 13515
1595 (B16A) CRV NO 3.8" 14.4 14226
1595 (B16A) CRV YES 4.2" 14.7 14416
1595 (B16A) CRV YES 4.0" 16.3 15137
1595 (B16A) CRV YES 3.8" 17.9 15933
1797 (GSR) SIR NO 4.2" 4.9 10888
1797 (GSR) SIR NO 4.0" 5.8 11433
1797 (GSR) SIR NO 3.8" 7.1 12034
1797 (GSR) SIR YES 4.2" 7.4 12195
1797 (GSR) SIR YES 4.0" 9.1 12804
1797 (GSR) SIR YES 3.8" 9.4 13478
1797 (GSR) LS NO 4.2" 6.5 11718
1797 (GSR) LS NO 4.0" 7.5 12304
1797 (GSR) LS NO 3.8" 9.1 12951
1797 (GSR) LS YES 4.2" 9.3 13124
1797 (GSR) LS YES 4.0" 10.3 13780
1797 (GSR) LS YES 3.8" 11.6 14505
1797 (GSR) CRV NO 4.2" 8.9 12871
1797 (GSR) CRV NO 4.0" 9.9 13515
1797 (GSR) CRV NO 3.8" 11.1 14226
1797 (GSR) CRV YES 4.2" 11.4 14416
1797 (GSR) CRV YES 4.0" 12.8 15137
1797 (GSR) CRV YES 3.8" 14.2 15933
1973 (B20 VTEC) SIR NO 4.2" 3.3 10888
1973 (B20 VTEC) SIR NO 4.0" 4.4 11433
1973 (B20 VTEC) SIR NO 3.8" 5.4 12034
1973 (B20 VTEC) SIR YES 4.2" 5.9 12195
1973 (B20 VTEC) SIR YES 4.0" 6.9 12804
1973 (B20 VTEC) SIR YES 3.8" 8.0 13478
1973 (B20 VTEC) LS NO 4.2" 4.8 11718
1973 (B20 VTEC) LS NO 4.0" 6.0 12304
1973 (B20 VTEC) LS NO 3.8" 7.1 12951
1973 (B20 VTEC) LS YES 4.2" 7.4 13124
1973 (B20 VTEC) LS YES 4.0" 8.6 13780
1973 (B20 VTEC) LS YES 3.8" 9.5 14505
1973 (B20 VTEC) CRV NO 4.2" 7.0 12871
1973 (B20 VTEC) CRV NO 4.0" 8.2 13515
1973 (B20 VTEC) CRV NO 3.8" 9.1 14226
1973 (B20 VTEC) CRV YES 4.2" 9.3 14416
1973 (B20 VTEC) CRV YES 4.0" 10.4 15137
1973 (B20 VTEC) CRV YES 3.8" 11.6 15933
Notes:
1. Blower RPM calculated for an engine RPM of 8500.
2. Boost is an estimate for a non intercooled/non-ported blower; Intake, exhaust, and camshaft selection will effect boost.
3. Blower heat becomes a significant problem on non-intercooled (or non-ported) blowers; running above 8 psi and is not advised.
4. Running above 12 psi regardless of setup is not advised.
5. An Endyn ported blower makes approximately 7% more boost.
Estimated Intake Temperatures
Boost Ambient Temperature Intake Temperature
6 psi 10 c / 50 f 53 c / 127 f
6 psi 20 c / 68 f 65 c / 149 f
6 psi 30 c / 86 f 76 c / 169 f
6 psi 40 c / 104 f 88 c / 190 f
8 psi 10 c / 50 f 67 c / 151 f
8 psi 20 c / 68 f 78 c / 172 f
8 psi 30 c / 86 f 90 c / 194 f
8 psi 40 c / 104 f 102 c / 216 f
10 psi 10 c / 50 f 83 c / 181 f
10 psi 20 c / 68 f 97 c / 206 f
10 psi 30 c / 86 f 108 c / 226 f
10 psi 40 c / 104 f 122 c / 251 f
12 psi 10 c / 50 f 103 c / 217 f
12 psi 20 c / 68 f 116 c / 240 f
12 psi 30 c / 86 f 130 c / 266 f
12 psi 40 c / 104 f 144 c / 291 f
Notes:
1. LHT intercooler should reduce intake temperatures by 28-38 C / 50-70 F
2. Ambient temperature is intake temperature prior to compression.
3. Calculations based on 65% Adiabatic Efficiency for 8 psi and below.
4. Calculations based on 60% Adiabatic Efficiency for 10 psi and 55 for 12 psi.
ITR 05082
Engine Management and Tuning
Oct 7, 2010 04:41 PM
gosu08
Apr 27, 2009 07:49 AM
jlfrnce
Aug 11, 2008 04:41 PM
DjBurns
Apr 18, 2007 08:39 PM
dariusz
Apr 14, 2002 05:57 PM
