you obd2 to obd1 converted guys
Old Dec 9, 2008 | 01:38 PM
skidmarkroyalty's Avatar
Default you obd2 to obd1 converted guys
i am converting an f23a4 to obd1 from obd2 and i am using using a converter harness for the dizzy, so my question is this: since i will be running a chipped p28, wont my timing have to my adjusted manually? and since it is an obd2 dizzy there is no way to adjust it is there? thanks for the help.
Old Dec 9, 2008 | 02:27 PM
technine's Avatar
You could adjust it by using an adjustable cam gear instead. Just adjust the cam gear and check the timing after to see how advanced or retarded you are.
Old Dec 9, 2008 | 02:56 PM
hmmm... thats interesting. and it makes sense. thanks alot man now i can stop hunting down an obd1 dizzy that will work.
Old Dec 10, 2008 | 05:22 AM
jweller's Avatar
You aren't going to be able to adjust spark timing with a cam gear. I guess indirectly you will, but thats not gonna be the optimum setup.
I have seen a distributor housing notched to allow adjustment. That is what I would do. Might take 15 minutes with a drill and a dremel.
Old Dec 10, 2008 | 05:35 AM
Turbowa's Avatar
Enlarging and oblonging the mounting holes is going to be the easiest thing to do. Your only other option is to get an OBD-I dist. assy. But you have to be able to adjust physical timing.
Old Dec 10, 2008 | 05:44 AM
Duane_in_Japan's Avatar
Adjusting the camshaft gear is the wrong way to go without looking at mechanical timing on an oscilloscope, spark timing in your case is the only way to go.
You can completely elongate the holes until there are no more holes, modify a large washer if its that far off, all you have to do is hold the dizzy from moving once the correct spark timing is set. Hopefully you wont run into issues at higher RPM, I am not a modify guy so I dont have that answer. I guess that is where the MAP in the programmed chip comes in, yes.
xxliljonxx1
14
Mar 21, 2012 07:57 AM
NirVTEC
Jul 24, 2011 12:05 AM
grodzef9
Jun 19, 2008 10:32 AM
Bngo731
Jan 9, 2006 06:00 PM
