where do u launch?
Old Dec 9, 2008 | 11:14 AM
hrs-kong's Avatar
Default where do u launch?
just wondering for type-s owner out there, how high do u guys launch at?
Old Dec 9, 2008 | 11:16 AM
Jdc5's Avatar
On the streets I launch at 3500 but on the track i use the rev limiter.
Old Dec 9, 2008 | 11:22 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I was dropping the k20 at 4,000. But the big one is setup... depends on your tires, trans, mods...
Also depends on your control. I can't wait to try launching with this new engine. woohoo
Old Dec 9, 2008 | 04:25 PM
square_1's Avatar
In my EP3 if I launch past like 3K it just loses tires. I guess maybe if I did the drag strip tire burn out to heat the tires it would maybe stick.
Old Dec 9, 2008 | 06:26 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Do you feather it or just hammer it?
Old Dec 10, 2008 | 12:29 AM
Jdc5's Avatar
You gotta feather it if you dont have upgraded clutch
Old Dec 10, 2008 | 01:04 AM
dc5RickK20's Avatar
7500 with my 2 step at the track on slicks...
Old Dec 10, 2008 | 04:23 AM
germanCTR's Avatar
vtec kicks in at 4000 too
Old Dec 14, 2008 | 10:57 AM
square_1's Avatar
That is one thing I haven't practiced too much is my launches... But as I am driving an EP3 with just bolt ons I don't really consider myself a drag racer anyway. Even when I hopefully get my JRSC I won't consider it a drag car. If I wanted a drag car I wouldn't have bought this thing. Haha. I would have built something else. I live for corners, my grandma could drive fast in a straight line.
Old Dec 14, 2008 | 12:01 PM
UTkid's Avatar
I tried to launch around or a little above 4k, I think that's best for me, stock tires and only CAI as mod.
http://www.youtube.com/watch?v=SBiMgpvb02g
Old Dec 14, 2008 | 12:27 PM
square_1's Avatar
Was that a Porsche you were racing? DIdn't seem like he was pulling too hard on you if it was!
Old Dec 14, 2008 | 12:51 PM
97blacklude's Avatar
there's more skill in it than just going in a straight line
Old Dec 14, 2008 | 01:34 PM
square_1's Avatar
I know. I just like my fun to last more than 10-14 seconds...
Old Dec 14, 2008 | 01:41 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
UTKid you should work on those track times...
When you launch are you just dumping the clutch and hammering the gas. Cause you really should feather it for better traction and a smoother quicker launch
Old Dec 14, 2008 | 01:48 PM
eMpAtHy's Avatar
and you can preserve the life of your axles as well.
Old Dec 16, 2008 | 07:12 AM
UTkid's Avatar
Besides taking my bike there once this was my first time running 1/4 mile in a car. First three times I did pretty much dump the clutch cus I panicked but last three runs I feathered it.
I did break a motor mount because of those runs haha so I have Avids now and that will help. I dunno I thought 14.9 was a slightly good time for just CAI?
I've seen people with more mods ont heir type s and do worse. I mostly autocross though.
And thanks for the advice.
Old Dec 16, 2008 | 06:51 PM
FwankieBoi's Avatar
I pulled a best of 14.6 with a hondata intake manifold gasket and short ram.. oh and 20psi on stock tires. I got new tire setup but when I went out to the track with it I ran my Integra instead this time and let my girl use the RSX as a place to sit and have the tools.
Old Dec 17, 2008 | 07:29 AM
Tyte-S's Avatar
The first car was a Mazda 3...the second was a Porsche...
Old Dec 18, 2008 | 06:26 PM
hrs-kong's Avatar
thanks for all ur advices...i'll put them to try in the spring!
Old Dec 18, 2008 | 09:54 PM
03K20A3Si's Avatar
With drag radials I launch at 6500rpm with the drive train preloaded Bogs a little but no wheel spin or hop. Best I got was 13.9 sec on just kpro
Old Dec 19, 2008 | 09:04 AM
iRockEP3's Avatar
bring it to 4k feather it till traction and drop it...
Old Dec 19, 2008 | 10:56 PM
02spoonep's Avatar
I have an 02 si with a2 swap and I launch mine at 7800 on 23x8x13 slicks.13.1@103 is my best so far.
Old Dec 19, 2008 | 11:11 PM
vk916's Avatar
On my DC5 I launch it at 3-4k
Old Dec 20, 2008 | 12:49 PM
rsxpat's Avatar
ummm i disagree if he's on street tires. doing a pre-stage burn out only helps if using a soft compound drag slick or drag radial. street tires do not have the same properties as drag tires. the street tire will loose its heat from the burn out by time you stage the car. the best thing to do on a FWD car with street tires is to ......
1st - avoid the water box
2nd - do a simple small short burn out for no longer than 5-10 seconds with the only purpose to clean the tire of all debris, such as road grime, grass, tar, gravel, small rocks, oil, trans fluid, coolant, etc...that someone else may have left on the road surface that you just happened to drive over while appoaching the staging lane.
3rd - launch at an rpm safe for you motor, axles, and the track conditions ( colder temp= lower rpm, higher temp you can launch higher rpm, generally )
i launch at 7500rpm, 2-step on, with drag radials. on street tires i feather it around 5000 in 2nd gear. lol 2nd gear bcuz 1st gear is useless with the torque i make on street tires. lol
best times so far
12.84@108mph 10psi drags
13.01@113mph 8psi streets
Old Dec 20, 2008 | 06:00 PM
hondaspecialist's Avatar
Banned
learn something new everyday
