F/T 91 crx si W/ jdm b16a type r NJ
I got a 91 crx si with a rebuilt jdm b16a. Car has a ton of work done, i put over 4k this summer into it. There is only 1500 miles since i finished it.but it still needs some work.Car has the following
jdmb16a all rebuilt
new main and rod bearings
type r water and oil pump
type r pistons and rings
moroso oil pan
ctr n1 crank pulley
civic 1/2 size aluminum rad w/ slim fan
gates timing belt
gates hoses
exedy 7.5lbs flywheel
xtd stage 3 6 puck clutch
aem short ram intake
dc 4-1 headers
test pipe
custom catback w/ ractive muffler
b16 trans
chipped and tuned p28 from phearable.net vtec-5600 limit-8500 cel shift-8100
obd0-obd1 converstion harness
new dizzy
msd cap and coil
accel wires
carbonfiber plug cover
polished valve cover
skunk2 sport shocks
omni power adj. coil overs
new rear calipers
new front wheel bearings
new cross drilled/slotted rotors and ceramic pads
steel braided brake lines
batt relocated in trunk
and im sure i missed alot, but you get the point. I but alot of time and cash into this car and hardly drove it. The biggest prob with the car is when i sent the head to the shop to get hot tanked and 3 angled i tried to save money and only replace what really needed to be replaced, so only about half of the quides were done the other half were just cleaned and put back in(big mistake!!) i should have just done them all, but i didnt and now when the car hits vtec it burns oil. runs and drives fine just burns oil in vtec. i did a compression test and got 240psi on all 4 cyl. I dont really have the time to keep putting into this car and i know ill never get back close to what i put in it but im just putting it out there to see what i might be able to get for it. Im not just going to give it away so please dont waste each others time with b/s offers, if i cant get a decent price for it, ill let it sit till the spring and finish it myself. Call or text with any ? 973-919-0257 Looking to trade for a sport bike all offers considered!! Let me know what you got
jdmb16a all rebuilt
moroso oil pan
ctr n1 crank pulley
gates timing belt
gates hoses
dc 4-1 headers
test pipe
b16 trans
new dizzy
msd cap and coil
accel wires
skunk2 sport shocks
new rear calipers
Read the Post n00b before you Reply!
Chris.
Chris.
i didn't know this subforum doubled as the 'cars you'd like to trade for a bike' section too. :-p i would think that most people in here are expecting to see people with bikes for sale, not people looking to aquire them.
i was JFWH anyways.
good luck with your trade, Si91CRX.
i was JFWH anyways.
ducati 1098
Sep 3, 2007 08:30 PM
