PROJECT 91's WTS/WTB and SERVICE thread!
all prices are pick up!
WTS:
DA parts:
90-93 gsr pw, p.locks, w/ panels or w/o (doors are clean, panels are clean it just needs a lil cleaning): 250 (150 for panels)(120 for doors)
DA front stock suspension (shock/spring/top hat): 40
DA front upper control arms: 30
DA front lower control arms: 50
DA rack and pinion w/ good outer tie end rods: 90
DA powersteering pump w/ high pressure line: 60
DA ps, res. (no lines): 15
DA gsr abs unit. (you pull what you need): 50
DA full gsr a/c: 120
DA gsr black front and rear carpet (needs to be cleaned a little): SOLD, 30 for the rear
92-93 GSR tranny w/ hole in casing (only 2500 miles on rebuild, tranny still spins and is a TRUE gsr, COME TEST IT OUT!): 180 just needs the casing and your good to go!
DA 92-93 gsr oem steering wheel (2): 25
94-95 ls dizzy, needs new ignitor (comes w/ wires): 25
Obd1 ls PR4 ecu (dinan chipped, i never personally used it but works): 100
90-91 DA driver side motor mount (good cond.): 40
92-93 DA driver side motor mount (have 2, one with head bracket and one just the mount): 40 each
90-91 DA stock oem bumper lenses: 15
92-93 DA stock oem bumper lenses: 20
DA blue seatbelts (front/rear): 30
DA driver side kick panel (no coin holder): 5
civic stuff:
99-00 Civic grill (white and ready for paint): 40
SOHC vtec solenoid (obd1 i believe): 30
92-95 civic oem headlights (headlights only, no corners): 40
b-series a/c bracket w/ pulley: 20
CHEVY/GMC newer trucks 6lug AMERICAN RACING rims (17x8 w/ goodyear tires w/ about 40% tread) rims are like new!!!: 250
(1) mercedezbenz s500 wheel in chrome w/ center cap. (also have 2 extra center caps): 120
ITEMS SOLD:
92-93 GSR front and rear cloth seats (clean set): SOLD!!!!
Exedy lightened flywheel (9.4lbs and was onlyused for 2500 miles): SOLD!!
90-93 GSR hood (white, clean w/ a supppper small ding): SOLD
Mugen MR5's silver (CLEAN!!) w/ tires (3 bfg's w/ 40% and kuhmo w/ 30%. definitely driveable tires): SOLD!!!
JDM 92-95 civic long armrest: GONE!!
92-00 civic or 94-00 integra buddyclub spec3 (ding on muffler, no cracks! just axle back): SOLD
92-95 civic hatch stock piping w/ cat and magnaflow exhaust: SOLD!
SERVICES:
alignments: 40bucks flat
oil changes: 15bucks flat for reg. oil (we use castrol oil, 5w30, also have full syn, and 5w20)
fluid flushes (coolant, man/auto trans, powersteering, brake, clutch)
used tires
brake jobs
mount/balancing
clutch jobs: 250 inlcludes clutch master flush
suspension upgrades
timing belt and water pump service: 150 for SOHC and 200 for DOHC
what ever you need done, i work on cars other than hondas/acuras. i can get good used tires for trucks and stuff. all work done at a shop. whatever you need done let me know.
if you have any questions just PM me or email me @ bb.mackin@yahoo.com
thanks for look!
-BOBBY!!!
WTS:
DA parts:
civic stuff:
ITEMS SOLD:
SERVICES:
used tires
brake jobs
mount/balancing
suspension upgrades
thanks for look!
-BOBBY!!!
when i bought the shell i sold to (Danger) it came on a LS and he said he had it rebuilt all with oem parts at a shop in LA. i believe him, he is a pretty cool guy. the shaft still spins. ill let it go for stupid cheap to. LMK
