FS: DJ gear - Technics, Denon, Sony, etc
It's time to sell my DJ setup. I don't really want to do this, but with 2 little kids running around now I just don't have time to mess with my turntables anymore. Plus, they're just going to break all this stuff sooner or later so I might as well sell it now
. The 1200's and headphones were purchased new in 2003, the mixer and cd player were purchased new in 2005 at Platinum Records here in Portland. I will have actual pics up this week, for now I'm using stock photos to give you an idea of how things look.
Technics SL-1200Mk2
I bought these brand new in 2003. I still have the original boxes, paperwork, and all the extras. Tonearms were always properly weighted, and the one time I moved them they were packed up properly to avoid any damage. They come with Ortofon CC Pro cartridges, and I believe I have a couple extra needles for them too. Asking $300 each or $500 for both.
Specs:
High quality for professional and DJ use / Universal S-Shaped Low Mass Tonearm / Gimbal Suspension / 33 and 45 rpm / Detachable Dust Cover
- Remember what DJs used in the club before the 1200s? Nobody else does either. That's because the turntable's heavy-duty design, vibration-resistant construction, and mechanical precision make a lot of what those early DJs did possible. This deck was the first to feature a Direct Drive motor, quartz movement for total accuracy, adjustable tone arm weights, anti-skate control, a pop-up target light and a sliding Pitch control. With each new improvement, as form follows function, the Technics turntable has become a thing of beauty. From the community centers at the beginning of the disco era to the clubs of today, the Technics SL1200MK2 sets the standard again, from a tradition that the series has championed for over 30 years. Vibration Resistant Construction - A die-cast aluminum body, heavy rubber base, and a lack of unnecessary components or empty space allow the 1200MK2 to absorb unwanted vibrations that could otherwise interfere with the sound.
- Ultra-Low-Speed Motor / Super-High Torque - The 1200MK2's ultra-low-speed motor and high torque (1.5kg/cm) allow for super quick start-ups (0.7 sec) and stops.
- Quartz Locked Pitch Adjustment - Allows for accurate quartz-locked pitch adjustments throughout its 16 percent (+/-8) range
- Total Direct-Drive Accuracy - Instead of just spinning the platter, the classic Technics Direct-Drive system actually incorporates it into the motor, reducing the number of parts that can malfunction and making consistent, accurate speeds possible. It's a system that has been providing fast start-up times and unequalled responsiveness for over thirty years. Wow & flutter 0.01% WRMS,, rumble -78dB
- Quartz direct-drive manual turntable
- Brushless DC motor
- Turntable Platter Aluminum diecast
- 13 5/64" (33.2cm) diameter
- Mass 3.74 lbs (1.7 kg)
- Turntable Speeds 33-1/3 rpm, 45 rpm
- Variable Range Pitch ±8%, ±16%
- Starting Torque 1.3 lb-in (1.5 kg-cm)
- Build-Up Characteristics 0.7s from standstill to 33-1/3 rpm
- Braking System Electronic brake
- Wow and Flutter 0.01% WRMS; 0.025% WRMS (JIS C5521), ±0.035% peak (IEC 98A Weighted}
- Rumble -56dB (IEC 98A Unweighted), -78dB (IEC Weighted)
- Unit Dimensions 17-27/32" x 6-25/32" x 13-31/32"; Weight 26.5lb (12 kg)
Denon DN-X1500
I love this mixer. I started off with a cheapo Gemini PS-626 which I had for a couple of years. Once I upgraded to this Denon, it was like night and day. It made me sound like I knew what I was doing
. I've had it for 3 years and still haven't used all the features it has. Originally $900 new, asking $500.
Specs:
Denon's flagship 4-channel mixer sets the standard for Club, Mobile and Battle DJs with powerful, innovative features that allow both flexibility and creativity. To achieve this exceptional performance, a floating 32-Bit SHARC Digital Signal Processor empowers the fully digital circuit, ensuring low noise and exceptional Audio fidelity. The Effector and Sampler are built-in to further boost the DJ's creative powers. The all new Flex Fader cross fader was carefully crafted to withstand the rigorous performance of the toughest DJs. Matrix Input Assignment: Eight input sources are freely assignable to any channel.
- High Performance Flex Fader w/tension torque adjustment: Linear contour control, Exceptional electrical and mechanical performance, Stainless steel slide rails, tension torque adjustment to 50 g/cm, Endurance tested contacts
- Sampler (CD Quality Sound): Utilizes audio from any of six mixer sources (Ch 1/2/3/4, Mic, Master) and offers Edit options including Loop, Reverse Loop, Stutter, Single Playback and A-B Trim with overall Pitch Control adjustment of up to +/- 100%
- Internal Digital Effects: Delay, Echo1, Echo2, Filter 1, Filter 2, Flanger, Auto Pan, Trans, and Key % over Ch1/2/3/4/Main Mic/Master, all with pre-cueing option and Dry/Wet mix control ****
- 3-Way BPM Counter - Auto/Tap/Manual Input: Developed to ensure that on-board effects are precisely synced with the music
- Constant Digital Output: 44.1 kHz, SPDIF: Allows you to Record directly to CD-R or hard Disc device via coaxial digital output terminal
- Mic Post Feature: Passes the Mic signal into BOOTH, REC or DIGITAL output signal path. A great feature to avoid feedback in the DJ booth or unwanted announcements on your recordings.
- Booth Output: You can pre-monitor any channel and effect through the booth output as you would with your headphones, only out loud!
- Frequency Response: 20 Hz to 20 kHz Signal to Noise Ratio:Line: 85 dB Phono: 73 dB Main Mic: 65 dB Total Harmonic Distortion (THD): Line: Below 0.02% Phono: Below 0.05% Cross Talk: Over 70 dB
- Unit Dimensions (WxHxD):12.2 x 4.3 x 12.9 inches (310 x 110 x 327mm) Weight: 14.7 lbs (6.7 kg)
Denon DN-S1000
Very nice CD player with pitch control, mp3 capability, etc. Asking $200.
Specs:
Weighing in at just 8 lbs. and measuring a mere 9" wide, the Denon DN-S1000 Compact CD/MP3 Player packs a lot of skratchability into its compact form. The killer DJ interface delivers the effects and feel of vinyl with a pressure-sensitive scratch disc, advanced MP3 functions, next track and cross-fade, 4 effects including Echo Loop, 3 platter effects, and 2 hot starts.
- Pressure-sensitive scratch disc
- Advanced MP3 functions
- Next track and cross-fade
- 4 effects including Echo Loop
- 3 platter effects
- 2 hot starts
Sony MDR-V700 Headphones
Superb headphones for critical applications or audio afficianados / 50mm drivers / Deodymium magnets / Swivel earcups. $50
Specs:
- The Sony MDR-V700DJ Studio Monitor Series DJ Headphones are superb performers whether you are spinning before a writhing mob, mixing a soon-to-be platinum CD, or melting into an old sofa in the Chill Out Room. Incorporating high-end materials and advanced engineering, the closed supra-aural, dynamic MDR-V700DJs deliver critically clean, exceptionally clear Sound for Professional and pleasurable applications. Swivel earcups for DJ and remix use enable single-sided monitoring; listen to house sound with one ear while cueing up the next track with the other
- Reversible earcups with auto return swivel mechanism
- 50mm diameter drive diaphragms enable superior power handling, deeper bass, lower Distortion and wider dynamic range; Frequency response is an outstanding 5Hz > 30kHz
- 3000mW power handling for the most stringent professional applications
- Neodymium magnets for 107dB/mW sensitivity
- Single-side 10-foot, oxygen-free copper cord with straight, Gold-plated Stereo Unimatch plug
- Silver finish
- Folding, supra-aural design
- Weighs 10.6 ounces without cord
. The 1200's and headphones were purchased new in 2003, the mixer and cd player were purchased new in 2005 at Platinum Records here in Portland. I will have actual pics up this week, for now I'm using stock photos to give you an idea of how things look.Technics SL-1200Mk2
Specs:
Denon DN-X1500
. I've had it for 3 years and still haven't used all the features it has. Originally $900 new, asking $500.Specs:
Denon DN-S1000
Specs:
- 3 platter effects
- 2 hot starts
Specs:
- Silver finish
damn, are they that much now? I paid $400 each for them, and it would have been like $375 each if I just got the regular silver ones. Yeah they come with cartridges and spare needles, and I have record cleaning brushes etc.
What's serato?
What's serato?
Serato is a program you use that let's you play your mp3s just like they are vinyl records. Best deal I've seen is what I paid for mine $450 new. Guitar center retails them for I think $700+. You're basically payin for the serato hardware, the little box that connects your laptop to mixer to tables. You nver have to buy another record again! Serato is something that might sway your decision on sellin those bad boys..
btw it is made by rane. What do they make that's not good?
Boost Ambassador
Texas -OK -LA (Sales)
Jan 4, 2006 02:00 PM
I miss my old Technics Grandmaster w/ Vestax 007 Setup.
