aem problem -coil wont fire-
I have a 96 civic hatch with a h22 swap,the car has ran great for 3000-miles or so,but out of no where stalled on me.. I had it towed and it is not firing.. I have replaced the coil and ignitor,with no luck.. I have fuel,compression is good timing is good,but no fire....
I checked the aem unit while trying to crank the car and coil 1 always says off.Im getting start sync. Did it somehow get turned off,or is the coil output dead on the ecu?How can I check?
Thanks for any input...
hope this helps
How to test the igniter (ICM) off-the-car
http://www.tegger.com/hondafaq/ignit...r-testing.html
http://www.tegger.com/hondafaq/ignit...ion/index.html
good luck!
good luck!
