97 Accord Lx swap Ex vtec motor
Old Dec 8, 2008 | 02:33 PM
chiLLaxcd7's Avatar
Default 97 Accord Lx swap Ex vtec motor
NEED HELPPPP!!!
My car was a Lx model i swap a f22vtec in it... But im having trouble with it.Before it was running on an Lx Ecu now its a Ex ecu, but it acts up. High Idle, around 1.5-2k, if i adjust the Dizzy to make it idle low it will shut off, so i leave it as high as 1.5-2k so the car wont shuts off... The gas is reallly strong..Also Sounds like its a misfired.. With the Lx ecu it wasn't acting up well it only can go up to 4k then it laggs and sometime the car shut off, i think its not enough power going to the Lx.. I had someone wired up the vtec for me too, but it still dont hit vtec. Either the guy did it wrong or its something.. Help me out anyone please, thank you.....
Old Dec 9, 2008 | 01:05 AM
Duane_in_Japan's Avatar
Sorry I dont have the ultimate answer but I would get a wire diagram for each car and start comparing pins on the ECU and go from there.
Old Dec 9, 2008 | 01:31 AM
GhostAccord's Avatar
Icon6 OBD2 Accord VTEC & Non VTEC ECU Pins
Here are the ECU pin outs for the 96-97 LX, DX, EX & EX-R Accords. The pins that are different between the B1 & B2 are in bold lettering. (F22B2 in red)
Pin Description Wire Colour
A1 INJ4 - YEL
A2 INJ3 - BLU
A3 INJ2 - RED
A4 INJ1 - BRN
A5 SO2SHTC - ORG/BLU OR ORG/BLK
A6 PO2SHTC - ORG/BLK
A7 BLANK
A8 VTS - GRN/YEL - F22B2 = BLANK
A9 LG1 - BRN/BLK
A10 PG1 - BLK
A11 IGP1 - YEL/BLK
A12 IACV - BLK/BLU
A13 MCS - GRN/WHT
A14 BLANK
A15 PCS - RED/YEL
A16 FLR - GRN/BLK
A17 ACC - RED/BLU
A18 MIL - LT GRN/RED
A19 ALTC - WHT/GRN
A20 ICM - YEL/GRN
A21 BLANK
A22 LG2 - BRN/BLK
A23 PG2 - BLK
A24 IGP2 - YEL/BLK
A25 IARSOL - ORG/GRN F22B2 = BLANK
A26 BLANK
A27 FANC - GRN
A28 2WBS - LT GRN/WHT
A28 VSV - ORG/GRN
A30 BLANK
A31 BLANK
A32 BLANK
Automatic Transmissions use the ECUs B connector
B1 BLANK
B2 BLANK
B3 SHA - BLU/YEL
B4 LCB - GRN/BLK
B5 LCA - YEL
B6 BLANK
B7 BLANK
B8 ATPD - GRN/BLU
B9 BLANK
B10 BLANK
B11 SHB - GRN/WHT
B12 ILU - WHT/GRN
B13 D4 IND - BLU/RED
B14 NMSG - WHT/BLU
B15 NM - ORG/BLU
B16 ATPR - GRN/RED
B17 ATP2 - GRN/YEL
B18 ATP1 - LT GRN/WHT
B19 BLANK
B20 BLANK
B21 BLANK
B22 NCSG - BLU/YEL
B23 NC - BLU/GRN
B24 ATPD4 - LT GRN/BLK
B25 ATPNP - LT GRN
C1 BLANK
C2 CKPP - BLU
C3 TDCP - GRN
C4 CYPP - YEL
C5 ACS - RED/WHT
C6 STS - BLU/RED OR BLK/GRN
C7 SCS - RED
C8 K-LINE - LT GRN
C9 BLANK
C10 VBU - WHT/YEL
C11 BLANK
C12 CKPM - WHT
C13 TDCM - RED
C14 CYPM - BLK
C15 BLANK
C16 PSPSW - GRN
C17 ALTF - WHT/RED
C18 VSS - ORG
C19 BLANK
C20 BLANK F22B2 = C20-PFSW-BRN
C21 BLANK
C22 BLANK
C23 BLANK
C24 BLANK
C25 BLANK
C26 BLANK
C27 BLANK
C28 BLANK
C29 BLANK
C30 BLANK
C31 BLANK
D1 TPS - RED/BLK
D2 ECT - RED/WHT
D3 MAP - WHT/YEL
D4 VCC1 - YEL/WHT
D5 BKSW - GRN/WHT
D6 VT P SW - BLU/BLK F22B2 - BLANK
D7 PHO2S - WHT/RED
D8 IAT - RED/YEL
D9 EGRL - WHT/BLK
D10 VCC2 - YEL/BLU
D11 SG2 - GRN/BLU
D12 SG1 - GRN/WHT
D13 SHO2SG - GRN/BLU OR RED/WHT
D14 SHO2S - WHT/RED
D15 PTANK - GRN/RED
D16 EL - GRN/RED
Last edited by GhostAccord; Jan 14, 2009 at 05:59 PM. Reason: Add a searchable Title
Old Dec 9, 2008 | 03:29 PM
chiLLaxcd7's Avatar
thanks, im still having problems. its getting me frustrated.. i check out the fast idle valve wasnt that. what else can it be, i should take it to someone who does the timing.im probably not doing the timing right...
Old Dec 9, 2008 | 08:43 PM
alkoholikwun's Avatar
f22b1 vtec engages low rpm, 2500-3000, for economy purposes. i did the JDM f22b(1) swap in my 92 accord. idles just fine. only thing i need is the correct ECU or chipped P28. right now im running the wrong ECU making redline at 5.5k and not 6.3k.
as for vtec, wire it straight to ECU. vtec solenoid wire + ground + vtec pressure switch.
check out cb7tuner and search for "f22b1 swap"
its how we roll!!!
Old Dec 10, 2008 | 09:59 AM
chiLLaxcd7's Avatar
Originally Posted by alkoholikwun
f22b1 vtec engages low rpm, 2500-3000, for economy purposes. I did the jdm f22b(1) swap in my 92 accord. Idles just fine. Only thing i need is the correct ecu or chipped p28. Right now im running the wrong ecu making redline at 5.5k and not 6.3k.
As for vtec, wire it straight to ecu. Vtec solenoid wire + ground + vtec pressure switch.
Check out cb7tuner and search for "f22b1 swap"
its how we roll!!!
was ur cb7 a lx model? Yeah that guy did wired my vtec to the ecu.
Old Dec 10, 2008 | 01:08 PM
92 accord ex 2dr
Old Dec 10, 2008 | 01:43 PM
chiLLaxcd7's Avatar
I will post a video on how the car sounds like maybe that way its easier for ppl to help me out! i really need help ...
1997 accord LX model
Swap a F22vtec
OBD2 to and OBD1 harness
LX ecu runs fine but cant really go pass 4krpm
EX ecu sounds like missfire, i move the adjust the TB and move the Dizzy,
I have to make it idle high around 1.5k and up so it wont shuts off.
Old Dec 12, 2008 | 07:24 AM
chiLLaxcd7's Avatar
hvnt had time to post the vid! been so busy lately!
Old Dec 12, 2008 | 07:41 AM
What OBD are the two ECUs I know the 97 Lx is OBD2 and you said something about switching to obd1 so I'm guessing that your EX is a 95 OBD1.
Are you running a conversion harness and if so who made it?
Sounds like you may have something mixed up in the conversion Pins. Possibly the injectors......
OBD1 wiring;
INJ1 - A1
INJ2 - A3
INJ3 - A5
INJ4 - A2
OBD2 wiring;
INJ4 - A1
INJ3 - A2
INJ2 - A3
INJ1 - A4
Old Dec 12, 2008 | 11:51 AM
chiLLaxcd7's Avatar
OBD1 wiring;
INJ1 - A1
INJ2 - A3
INJ3 - A5
INJ4 - A2
OBD2 wiring;
INJ4 - A1
INJ3 - A2
INJ2 - A3
INJ1 - A4
Im using the jumper harness...obd2 to an obd1 harness.. my ecu is POA
Old Dec 12, 2008 | 12:45 PM
Where did you buy the jumper harness?
Is your check engine light coming on?
Old Dec 12, 2008 | 01:01 PM
chiLLaxcd7's Avatar
from street lights i think they have a website, yeah my check engine light is always on...When i get home i will try to post the video so u can hear how it sounds like..
Old Dec 12, 2008 | 01:04 PM
While your shooting the vid you should try retrieving the codes from your ECU. That will give us an even better indication of what the problem may be.
Old Dec 14, 2008 | 11:12 PM
chiLLaxcd7's Avatar
i still havnt got the code yet but i will asap..
Old Dec 14, 2008 | 11:51 PM
YeuEmMaiMai's Avatar
forget adding v-tec get the ex intake and a better header that will give you the 10 out of 15 hp for a lot less money
Old Dec 15, 2008 | 02:22 PM
chiLLaxcd7's Avatar
Helpp!!
Old Dec 15, 2008 | 03:23 PM
Have you had a chance to retrieve the Diagnostic Trouble Code yet?
From the video it looks like it could be a few different things.
Timing could be off, plug wires crossed, fuel injectors not firing in sync. EGR solenoid open during idle. MAP & TPS connections mixed up. If you get the codes It will make it a lot easier to help you.
Old Dec 16, 2008 | 12:27 PM
chiLLaxcd7's Avatar
i think my motor is gonee ...do i hear Hseries? hahaha
Old Dec 17, 2008 | 08:13 AM
bigsnorlax's Avatar
sorry i cant help but out of curiosity what does OBD actualy stand for? or they just random letters haha
Old Dec 17, 2008 | 09:11 AM
IIRC it stands for On Board Diagnostics
Old Dec 17, 2008 | 09:13 AM
bigsnorlax's Avatar
alright haha thanks
Old Dec 17, 2008 | 09:43 AM
No problem
Old Dec 17, 2008 | 09:51 PM
chiLLaxcd7's Avatar
I think one of my piston is gone this motor is gone lolol..waste money fixing it..I'm do a build thread again...gettin me an h22...anyone knw where I can get it @? 97-98 model.....but thanks for everything guys especiallly ghost =}
Metalzone
Honda Civic (2001 - 2005)
16
Aug 3, 2015 12:04 PM
EgK2o09
Oct 20, 2009 12:23 PM
sony224422
Jan 2, 2008 12:22 PM
BigRonDawg
12
May 9, 2006 06:55 AM
AccordTypeR6
Mar 31, 2003 06:44 PM
