Suspension & Brakes Theory, alignment, spring rates....
so i hear itr springs will fit my 00 si
Old Dec 8, 2008 | 02:24 PM
swizz977's Avatar
Default so i hear itr springs will fit my 00 si
im just gonna get the fronts cuz my front is way to low with my hnr sports springs idk y.. but what year would fit and if any1 can show me what it would look like..
Old Dec 9, 2008 | 09:22 AM
swizz977's Avatar
how high will this actually be?
Old Dec 9, 2008 | 11:14 AM
. a d a m's Avatar
most likely close to stock or perhaps even a bit higher.
Old Dec 9, 2008 | 06:17 PM
BlueIntegraBoy's Avatar
Any 90-01 Integra springs will fit your car
Old Dec 11, 2008 | 08:15 AM
blaze the chemi's Avatar
A local autoxer bought Koni's with ITR springs for his Si and it looked really good. A little lower than stock, but just enough fender gap to look nice. Just get that setup and it will look even on all 4 corners.
Old Dec 13, 2008 | 02:41 PM
paopao's Avatar
Koni Yellows w/ITR springs on lowest perch all around:
Old Dec 13, 2008 | 03:07 PM
miro_gt's Avatar
^ I like your drop very much.
if I put Eibach Sportline springs on mine (with koni yellows), do you think it will look about the same as yours ?
Old Dec 14, 2008 | 06:50 AM
paopao's Avatar
I'm not sure, you could probably search the suspension forum and find some pics though.
Lowering springs should only be used on the middle perch, while OEM/stock springs can be used on the lower 'sport' perch.
Old Dec 15, 2008 | 07:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Why is that? When I had H&R Sport springs, I had to set the rears on the lower perch setting to even out the height. On the middle setting, the rear was WAY higher than the front. The raked look was awful. With properly-trimmed bump stops, I had no problems running the Sport springs on the lowest perch of the Konis in the rear.
The front is a different story. Had I put those on the lowest setting with the H&R Sports, the front of the car would have been on the ground, probably not drivable.
Old Dec 15, 2008 | 07:55 AM
paopao's Avatar
I believe CRX Lee had posted once this information, but I would have to find it first.
I do agree with you that the fronts w/lowering springs on the lowest perch is probably asking for trouble.
EBPSI
Suspension & Brakes
Nov 1, 2010 10:26 AM
Girl
Jul 4, 2004 10:42 AM
mikestypeR
Apr 7, 2004 06:29 AM
TeGGY_LS
Mar 30, 2004 11:19 AM
memphiss13
Apr 10, 2002 09:44 PM
