Best Oil
Old Dec 8, 2008 | 02:12 PM
gonein60seconds's Avatar
Default Best Oil
in your own opinion what oil do you think is best for 96 stock ls
Old Dec 8, 2008 | 02:16 PM
biggoofy's Avatar
i use motul
Old Dec 8, 2008 | 02:21 PM
ryanevansoh's Avatar
Do you mean brand or weight?
Old Dec 8, 2008 | 02:25 PM
Thrule01's Avatar
amsoil
royal purple
motul
to each his own....
Old Dec 8, 2008 | 03:41 PM
ALLxMOTOR EG's Avatar
Vietnamese!
royal purple and mobile 1
Old Dec 8, 2008 | 04:22 PM
what about weight
Old Dec 8, 2008 | 04:27 PM
Evil Ryu's Avatar
one that you change regularly..lol
for that car, i would use castrol gtx 10w30 and a purolator pure one filter.
change it every 3k or earlier depending on how you drive.
for a performance build, after the break in period i would probably use amsoil 0w30, or if i had money to burn i would use torco's top of the line oil.
i would also use a zinc oil additive.
Old Dec 8, 2008 | 04:57 PM
racebum's Avatar
a lot of this depends on the clearances used in the motor. loose motors normally run better with 10-40 or 20-50, stockish tighter ones like 5-30ish. anyway there is a multi page thread on this already in the all motor forum.
Old Dec 8, 2008 | 06:15 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I started using Valvoline MaxLife 5w-30 oil year round back in 2002 at about 115K miles. Now 6 years later the car has 272K miles and still runs like a top and gets 32-35 mpg. I change the oil every 3K miles and use an STP oil filter. The engine is pretty much bone stock.
Old Dec 8, 2008 | 08:22 PM
biggoofy's Avatar
I used to use royal purple it works great to 5w30
Old Dec 8, 2008 | 08:53 PM
96teggynonVtec's Avatar
German Castrol 0w30
Old Dec 8, 2008 | 09:07 PM
uses0ap's Avatar
petroleum based 10w-30 FTW with my old car =]]
Old Dec 8, 2008 | 09:08 PM
da9_2NR's Avatar
royal purple or mobile 1 4 me.
Old Dec 8, 2008 | 11:48 PM
DcLs's Avatar
i use shell 10w-30 from auto shop but i suggest mobile 1 tho
Old Dec 9, 2008 | 12:38 AM
racebum's Avatar
this is good stuff along with the shell rotella diesel oil. for the price it's hard to beat since it's loaded with zinc
Old Dec 9, 2008 | 01:31 AM
Hyoriu's Avatar
I use Castrol GTX High Mileage Formula 10w30.
My engine runs smooth as butter with this oil. Changed every 3k miles or when needed depending on driving habits etc...
Old Dec 9, 2008 | 02:22 AM
95DC2GS-R's Avatar
http://www.amsoil.com/storefront/xlf.aspx
That's what I use. I get it at dealer cost.
Old Dec 10, 2008 | 12:50 AM
jdmDAsix's Avatar
i use mobil 1 full synthetic 10w-30.
Old Dec 10, 2008 | 04:12 AM
MelszEg6's Avatar
I like the Mobile 1 also^^
Old Dec 10, 2008 | 01:16 PM
rebar71's Avatar
I use Mobil 1 Synthetic 5w-30 - 132k miles
Old Dec 10, 2008 | 01:24 PM
neardon's Avatar
I'm a Jackass
Wal-mart brand "super tech" 10w40 and change it every 5k miles. 200k+ and still running strong.
Old Dec 10, 2008 | 01:40 PM
PreyStayShun's Avatar
Totally agree w/Neardon. Wal-mart brand oil all the way!!! Never caused me any harm!
Old Dec 10, 2008 | 01:54 PM
neardon's Avatar
I'm a Jackass
I figure by the time it actually does any severe harm to my motor or cause it to blow, I will have saved way more than enough for a motor swap.
Old Dec 10, 2008 | 01:58 PM
nsxtasy's Avatar
H-T Order of Merit
I use 5W30 because that's the viscosity recommended by Honda as best for our engines, at all ambient temperatures. (They say you can also use 10W30 when it's above freezing out, but 5W30 is still preferred.) If you check your owners manual or service manual, you'll see that this is true for all Integras sold in North America.
I use 100 percent synthetic oil because it's more resistant to breakdown when hot, and has better flow characteristics when cold, than conventional oil.
I get whatever major-brand full synthetic oil is cheapest, usually either Mobil 1 or Pennzoil Platinum.
Old Dec 10, 2008 | 10:13 PM
lopes316's Avatar
I use castrol synthetic 10-40W. 254,000 miles. Performance all motor.
