Antifreeze Container and Engine Temperature gauge
Old Dec 8, 2008 | 01:55 PM
katanamast279's Avatar
Icon2 Antifreeze Container and Engine Temperature gauge
I have a 1995 Integra. And for some reason my antifreeze container always overflow, and boils. The guys at the dealership at first said it was the radiator. But i had a brand new one put in about 2-4 weeks ago. And it still has the same problem. Also my Engine Temperature gauge instide the car goes way past the limit too. The engine doesnt seem to be burning. If this occurs and i take the oil cap off, white smoke comes out of it. Does anybody have a solution to these problems? If so please write back. All suggestions welcome
Thank you for your time
Old Dec 8, 2008 | 05:11 PM
TunerN00b's Avatar
When was your thermostat last replaced?
If it is failing to fully open, you could be overheating the car despite having a fully operational radiator, which would cause coolant to flow into the overfill bottle.
Old Dec 8, 2008 | 06:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Boiling coolant means that it's either not holding pressure (higher pressure raises the boiling point), or it means that there isn't much coolant in there, i.e. it's mostly water, or it could be both of those.
Old Dec 8, 2008 | 06:35 PM
weavertime1's Avatar
Just to throw this in here...driving your car to the point where it constantly overheats is not a good idea...
Old Dec 8, 2008 | 07:38 PM
biggoofy's Avatar
i run almost all water and i never over heat but check ur cap and thermostat
davidbuccaneer
10
Nov 23, 2015 12:40 AM
Emilytcivic
Honda Civic (2006 - 2015)
Nov 22, 2014 04:54 AM
hondaluv345
10
Sep 6, 2013 05:47 AM
unautomobiled
Nov 13, 2010 08:22 AM
project civic
Mar 16, 2006 09:46 AM
