Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Power LOCKS NOT WORKING when Car off
Old Dec 8, 2008 | 12:00 PM
johanG's Avatar
Default Power LOCKS NOT WORKING when Car off
Hey guys i dont know wuts going on with my civic the other day i was installing a double din and then when i put my alarm i realize they the locks werent on n then i realized that when the car is off the power locks dont work but when the car is on they r working and then i checked the DOOR LOCK fuse in the fuse box next to the engine and it seemed okay... If anyone know what's wrong with the power locks that arent working with the car is off please tell me and if its a fuse or something
Thank you
Old Dec 8, 2008 | 12:31 PM
unevolved's Avatar
Probably not a fuse if they're working when the car's on. You must have messed up the wiring somehow installing the alarm, accidentally wired them into the wrong circuit or something. It's hard to diagnose what you're actually dealing with unless you give us more information.
Old Dec 8, 2008 | 12:37 PM
johanG's Avatar
I didnt installed an alarm just a double Din TV and then i see the a friend just opened the door with the alarm on and then i realized the it was the power locks arent working when the car is off but when its on it works just fine but i dont know what it is
Old Dec 8, 2008 | 04:50 PM
DynastyRacer22's Avatar
i got the same problem orginal owner spliced the oem harness so i had it hardwire to a new deck and since then the door lock only works when the car is on lol
Old Dec 8, 2008 | 09:27 PM
It Wasn't Me's Avatar
$8 harness adapter > electrical issues
Why people butcher their harness, instead of doing it the right way, is beyond me.
Old Dec 9, 2008 | 05:30 AM
Harlowe's Avatar
Function>Fashion
Check the "Back Up" Fuse, under the hood. I had a similar problem when wiring a gauge cluster.
Old Dec 11, 2008 | 12:16 PM
johanG's Avatar
yea it was the Back Up sensor thanks.
Old Dec 11, 2008 | 05:09 PM
pr0j3xt01v1c's Avatar
which number is the fuse? #9 with a 10A fuse?
Old Dec 11, 2008 | 05:57 PM
Harlowe's Avatar
Function>Fashion
You're welcome.
Old Dec 5, 2024 | 04:17 PM
darkknight2ss's Avatar
Default Re: Power LOCKS NOT WORKING when Car off
bro! Thank you for this, this just saved me after having an issue with installing an OEM Honda alarm/ key fob system under the head unit. Accidentally touched wires with bad electrical tape job and my locks were doing the same thing this guy was saying. And along with my head until no longer working and my “anti-theft” green key light on the cluster, no longer popped up and couldn’t find the problem for the life of me with fuses that I’d assume they were and after checking the wires for load and it all being good. Then you said this and I ran out and checked the “Back Up/ Fuse #9” under the hood and bam! There it was! Blown 10amp fuse! Everything is now back up and running! Key fob lock, and head unit all good! Thank you again 😎🤝🏼
mish__
Audio / Security / Video
Sep 4, 2013 11:23 AM
EracerUgone
Jul 24, 2011 01:03 PM
Rizzen
Sep 21, 2008 01:35 PM
jnet
Oct 28, 2004 11:21 AM
integra15
Sep 2, 2001 06:01 AM
