how getting 12.5:1 cr on b16a2?
hi!
Thats my first post in the Civic Forum since I am registered here on h-t I think
Well, a customer of mine needs to get out a c/r ration about 12 - 12.5:1. How to do that? He has to stay with 1.6i - cause of the competition class he race.
All I find a JEs, etc with max 11:1 c/r.
It seems the P30 b16b pistons with about 11.5:1 is the highest I can find.
Anyone knows the trick how to do it?
thanks
thanks
Well, your only option is to skim the head. This results in a combustion chamber with a smaller volume, thus increasing c.r. A good engine machine shop will advise on how much to skim off to get your desired figure (plus making sure you won't end up with a piston / valve interface - very expensive damage !!)
p30 is the jdm b16a piston. with the stock head gasket and a stock head(no shaving) you'll have 10.4:1 compression.
if you want 12-12.5:1 you'll need aftermarket pistons, and possibly an aftermarket headgasket. raising the compression from 10.4:1-12.5:1 cannot be done simply by shaving the head.
baz_ctr
Mar 27, 2009 01:42 PM
1SIKZ06
Mar 4, 2009 12:59 PM
84mm Cp Pistons!i wan to know how much compression this set pistons can gain wif B20B and B16A2 head
B20[Vtec]
37
Mar 22, 2005 05:27 PM
Hoodwinked
Jan 19, 2004 08:34 PM
