ecu help!!
Old Dec 8, 2008 | 09:19 AM
callmetree19's Avatar
Default ecu help!!
last night i finish and b16a swap in my 94 civic ex.. i start the motor last night and i threw two codes 10 and 14, so i took a look at the codes, and it had that my IACV is bad and i dont know what the 14 i.. but should i just buy a new one and take it to a shop about the code 14?
Old Dec 8, 2008 | 09:42 AM
messeduprex's Avatar
10= IAT (Intake Air Temprature)
14= IACV (Idle Air Control Valve)
If im correct i belive both plugs as the same it's possible you just have them switched around i've run into that problem only with the MAP and IACV switched.
altran
Jan 31, 2008 09:53 AM
latinracerct
Dec 6, 2006 01:24 AM
Intellect
Feb 3, 2006 12:10 PM
beedoublejay
Aug 21, 2005 03:28 PM
beau_safken
Apr 3, 2003 08:31 PM
