H22 in a 94 ex
Old Dec 8, 2008 | 08:17 AM
Decaf's Avatar
Default H22 in a 94 ex
so i found this deal on a H22 engine, but before i went ahead with it i had some questions.
yes i know with time, money and modification anything will fit, but how much money and mods would this take to fit into my 94 ex coupe. im expecting axels engine mounts, but what else? harness exaust? what type of transmission would i need? im betting that my stock tranny wouldnt work so what type of tranny do i need?
thanks alot in advance
Old Dec 8, 2008 | 08:41 AM
1LowSol's Avatar
It's gonna be alot of work, Suspension and so on, I would suggest a B Swap. Prolly the easiest and WAY cheaper than a h22.
Old Dec 8, 2008 | 08:47 AM
DTA-Zombie's Avatar
don't answer if you aren't sure
h22 in a civic is actually quite common - you can use an H transmission and shifter but great success using the H2B adapter plate to use the b series transmission - I haven't seen one yet but heard of one for a d series as well.
you do have to do a bit of banging to give the alternator clearance - but mounts, "custom" axles if using the h series tranny - I'd probably go ahead and pick up a prelude harness but modify yours to fit or work - never done the swap so not sure what sensors or anything needs to be changed. exhaust - any 2.25 or 2.5 will be fine -
it isn't the most common swap - and gives you a higher starting point than a b series for negligible cost difference.
Old Dec 8, 2008 | 08:51 AM
1LowSol's Avatar
Lol my point proven. I NEVER said you can't do it. All i said is it's easier to do a b swap. SO how i answered when i "Wasn't Sure" is kinda making me wonder. I was just answering from my experiances. But thank you for throwing that out there.
Old Dec 8, 2008 | 09:04 AM
DTA-Zombie's Avatar
honestly - it is no harder than doing a b series in a crx or 88-91
suspension - meh not really I would do suspension and strut bars/tie bars anyway
the h22 overall weighs like 50 pounds more than the typical b series
the easier/cheaper etc is why I said not sure...
I'm actually in the process of getting everything to do an all motor H22 CRX
Old Dec 8, 2008 | 09:27 AM
nix94delsol's Avatar
H22 swap is tit, im acutally in the process of putting one in my del sol right now
General Info: https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
Mounts: http://www.nolimitmotorsport.com/prod/EGH1
More General Info: http://www.civicland.com/forum/honda...swap-info.html
Axle Info: https://honda-tech.com/forums/hybrid-engine-swaps-18/additional-h22a-civic-axle-information-434668/
Im a huge H series guy, more for your money.
jOnW89
16
Oct 21, 2009 06:19 PM
ferton2003
10
Feb 21, 2007 08:05 AM
accrdkid94
May 11, 2006 09:38 AM
inTeGra_LivesOn
Jan 1, 2005 07:39 PM
jonjon149
Mar 25, 2004 09:56 AM
