Door will unlock but not open
Old Dec 7, 2008 | 11:11 PM
Tarlacon's Avatar
Default Door will unlock but not open
First off, I have done a search of this topic and everything I found required the door to be open in order to fix the problem.
About 2 weeks ago I locked my doors (power locks) and closed the driver-side door. About 2 hours later I went to get in my car and unlocked it with the key. It unlocked fine, but the door wouldn't open, I then went through the passenger side to try and open it from inside, wouldn't budge. I called AAA to open the door so I could take off the panel and assess the problem, they couldn't do anything. The guy said that he couldn't pop the latch with a slimjim.
What should I do? kinda getting sick of driving my sisters car
Old Dec 8, 2008 | 04:36 AM
charlie0801's Avatar
the rod that connects the door handle to the actual mechanism is probably broken/out of place. to get to it you will have to remove the door panel but how you are going to do that withought opening the door... i have no idea.
Old Dec 8, 2008 | 04:45 AM
prelude_h22vtec's Avatar
yeah i dont think its possible to remove the door panel with the door closed. if that guy can jimmy it open, do that. and then pull the door panel and inspect the latch mechanism and the linkage going to the handle/s
Old Dec 8, 2008 | 10:07 AM
MLBZ521's Avatar
Only thing I can think of at the moment, is remove the Door Switch Panel and see if you can put some light in there as see anything...
If you can, you might could possible finagle a cloths hanger in and possibly somehow pull the door rod and open the door...
But first, take the switch panel off and see if you can see anything.
Old Dec 8, 2008 | 11:35 AM
Tarlacon's Avatar
Thanks guys, i'll try those ideas
Old Dec 9, 2008 | 08:52 AM
SKDRCR's Avatar
You could also try taking off the little cup on the armrest that's on the door
panel. It's held in by one phillips screwdriver.
Old Dec 9, 2008 | 04:56 PM
Crash_Control's Avatar
In the past when I have had to get someones door open after some one "slim jimmed" it what I did was to lower the window then manipulate the rods to the latch by going between the door glass and the weather stripping.
Old Dec 13, 2008 | 09:14 AM
kingh90's Avatar
this happen to me and it was the door locks in side the pannel. i went to my nearest audio shop and they installed new ones for 60 and i have lifetime warranty on them thru the shop....i would say take it to your nearest honda dealer and have them take a look, or any place that doos custom shaved doors and stuff like that
Old Dec 13, 2008 | 01:49 PM
slamdlude's Avatar
Take it to a locksmith shop. They should be able to get your door open and fix whatever is wrong with it.
Old Dec 14, 2008 | 03:54 AM
TreWatts's Avatar
same thing happened to my car.
to be honest, the only thing you can do is to try your best to get the panel off without breaking it, then airhammer the latch until it breaks off. door should open then, and you'll have to replace the striker and probably the actuator.
i had a co-worker (at the honda dealership) do it, because i didn't trust myself with the door panel thing.. and didn't have an airhammer.
draladriver
Feb 1, 2014 01:55 PM
suhteevin
Jan 6, 2009 09:04 PM
Frost7177
Oct 27, 2008 01:31 PM
pstanger
Aug 22, 2007 08:58 AM
itsmedavid
Aug 9, 2007 03:19 PM
