FS: Complete K24A8 longblock KY
Well I was about to dump a lot of money into parts to build this motor this week but now I'm second guessing the build. Wanting to see if I can move this before I change my mind. Motor is a K24A8 out of a 06 Accord with approximately 30k miles on it. Was bought from nikos, here is the original thread. http://www.k20a.org/forum/showthread.php?t=39447
Motor is a COMPLETE longblock minus a few missing bolts here and there. Only thing missing are the alternator, starter and p/s pump. Comes with intake and exhaust manifold, throttle body (which will be no use if you are planning to do the swap in a pre-drive by wire car since this is a drive by wire throttle body) complete UNCUT harness with coils, water pump, thermostat etc etc. Motor is pretty much disassembled except the head but everything is there to put back on. The head was NEVER pulled off. Like I stated, I was about to order a bunch of parts and drop the block off at Bell but now I'm in a pickle, hence why it's disassembled. The valve cover looks the way it does because of paint stripper. Perfect for a back up motor for your 06-07 Honda or a build.
$650 NO LOWER AND NO TRADES SO DON'T BOTHER ASKING. Not looking to ship right now, but might consider it if you are serious. Located in Louisville KY.
intake side
exhaust side
IM on motor
2 piece IM
intake side
exhaust side
IM on motor
2 piece IM
