painting bumper
No, do not use bondo on a urethane bumper. You need to use a flexible urethane filler,or a urethane repair two part epoxy that you can shape to form. If your trying to fix the RASH on the bumper from say scraping something, the two part epoxy repair is the best solution. you need to sand the plastic. use a certain spray chemical to remove the oils, than mix your two part repair and just lay it on, after that you can sand it down and shape it how you want it. than you need to prime the hell out of it. Using bondo on urethane will crack in a matter of days, a matter of hours if you are too rough on it.
A d/a is an air powered sander.
can i get the flexible urethane from checkers or a napa?
mamaboy
Jun 16, 2005 09:03 AM
Jay J
Aug 7, 2003 01:06 PM
