Cruise Control on s2k steering wheel
hey guys i just installed an s2k steering whell on my 96 coupe and was wondering if the oem cruise control buttons will fit onto the s2k steering wheel? i got my s2k wheel without the cruise control buttons on them but i would like ot run thme because i still have c/c in my daily. thanks for the hlep guys.
thats what i figured, they are angled slightly different. i cud make the civic one work but it would probably look funky. so do the s2000 cruise control buttons plug up? or do i need to chop the plug to make it work?
You need to use the s2000 plug on the civic harness. There was a thread a while back on how to de-pin the plug and change the wires around to make it fully functional with no cutting / soldering. I have done this on my 99 si - I'll try and find the thread since I don't remember the pinouts.
sweet, it is just 2 plugs so i cant be anything too crazy. thanks for theh lp guys much appreciated. its hard to get an answer on here sometimes without people calling you an idioit or an *******
If you look at my above post I uploaded two PDF files. It lists the pinout for both connectors and all you have to do is match them up correspondingly.
In other words, the Civic one went:
1) Ground
2) Output #1
3) Output #2
4) Blank
5) Blank
S2000 went:
1) Output #1
2) Blank
3) Ground
4) Blank
2) Output #2
So depin both connectors and then take the civic pins and match them up to the s2000 pinout provided for the connector, make sense?
1) Ground
2) Output #1
3) Output #2
4) Blank
5) Blank
S2000 went:
1) Output #1
2) Blank
3) Ground
4) Blank
2) Output #2
Those of you needing this info....
Civic wires to s2k wires
Red to blue/red
Blue to green/black
Grey to green/red
Took a lot of research and a couple tries. Hopefully this helps someone
Red to blue/red
Blue to green/black
Grey to green/red
