Suspension & Brakes Theory, alignment, spring rates....
brake disc question
Old Dec 7, 2008 | 06:55 PM
LaCuRa's Avatar
Default brake disc question
whats up guys, i did a jdm 5 lug conversion for my teg, and for some reason my car starts to shake after 30mph and it feels like its coming from the front passengerside , the mechanic checked it out and said my disc is is causing the shaking, is this possible? but my steering wheel dont shake, but my whole car does, and i notice if im goin 30mph or more and i turn right it doesnt shake but once the car is back straight it does it again, and if i do it turning left it will still shake, any suggestions on what i can be?
Old Dec 8, 2008 | 06:09 AM
hatchling37's Avatar
A rotor would not just cause your car to vibrate, unless it's vibrating when you're hitting the brakes. Check all your suspension for loose nuts, look for bad front end parts, check your wheel balance, how old are your shocks?
Old Dec 8, 2008 | 11:31 AM
Katman's Avatar
Sounds like your passenger side axle nut could be loose and not snugging the outter joint into the wheel hub completely. Check it and tighten it down.
If you find the axle nut is tightened already, it could be a bad wheel bearing going bad. Jack the car up enough so that the tire isn't touching the ground, grasp the tire at the 10 and 2 o'clock position and try jiggling the wheel and feel if there's any kind of play or if you hear a knocking sound. If so, the 5-lug wheel bearing is bad.
Warped rotors would cause your steering wheel to shudder or shake upon braking only. If there's no braking, you will not experience shuddering.
Also, get an alignment if you haven't already.
Old Dec 8, 2008 | 07:23 PM
LaCuRa's Avatar
thanks alot guys, well i did my front end last summer 2007, my shock i always haddem since day 1 that i bought my car back in feb 07, my wheels got balance and align 2 weeks ago with brand new tires, i thought it coulda been caused by the old tires so i got new tires all around, the axle bolt is tight, so im guessin it has to be the wheel bearing, if so, i got the jdm 5 lug suspension can i jus go and buy it for a usdm type r?
Old Dec 8, 2008 | 11:55 PM
Katman's Avatar
JDM ITR uses a 36mm outter joint so no, you can't use a US ITR wheel hub, you'll have to go with either a CRV or Prelude hub.
Actually, double check and see if your front axle nuts are 32mm or 36mm to be sure. If they're 32mm then you can go with a US ITR wheel hub.
Old Dec 9, 2008 | 05:37 PM
LaCuRa's Avatar
no its 36mm, i had to put the crv axle on my car, but ima go to a mechanic shop tomorrow and lettem check it out
Old Dec 11, 2008 | 10:34 PM
burningrex's Avatar
sounds like a bearing to me for sure!
just took my friend to get his pressed out a few days ago...
Old Dec 12, 2008 | 09:27 AM
LaCuRa's Avatar
ok i got it done it wasnt the bearing, i had bought the crv 5spd 2wd axle off a 99 as told but for some reason it was the wrong axle, the axle was a 1.25in to long so the axle did not have any play, also i took advantage and rebuilt my rear passengerside caliper, so now my car is riding good, thanks alot for the help guys, howeva i got 1 question, my suspension is off a jdm itr, now my question is, is the caliper the same as a usdm itr? are the rotors the same as a usdm itr, also my boy told me the rear caliper is the same a 4 lug teg is this true?
Old Dec 14, 2008 | 09:12 AM
Katman's Avatar
glad to hear you figured out the front end shuddering problem
US and JDM ITR 5 lug rotors & calipers are exactly the same.
Your rear caliper is NOT the same as a 4 lug teg. ITR rear's have a slightly bigger piston and the offset to accomodate the bigger rotor.
The ITR model that shares the same brake size as a RS/LS/GSR is the early JDM 96-97 ITR which sported the 4x114 lug pattern.
Old Dec 14, 2008 | 06:00 PM
LaCuRa's Avatar
thanks alot for that info
truevietluv636
Sep 8, 2007 03:00 PM
cmyrex
Nov 14, 2006 08:28 AM
Chicano
11
Jan 19, 2005 08:14 PM
95BlkGSR
Dec 15, 2004 06:15 PM
GeeSeeR
Aug 4, 2001 03:07 AM
