how do you remove ek sideskirts?
So I dont know how to take off the clips to remove that stock civic 96-00 sideskirts. I tried searching here and gooogle and the only thing that I came up with is that you have to slide them forward but that was no help at all. Please help me.
there are 2-3 screws on the front of the sideskirt you have to take off. its behind the fender lining i believe and 5-6 clips under the sideskirt... once you take the screws off and clips you can slide the sideskirt forward.
Yeah I was clueless when i was swapping front ends.
There are two screws in the front of the sideskirt behind the tire.
There are also three of those bastard plastic plugs with plastic screws along the bottom of the sideskirt, they will strip, so use two flathead screwdrivers to pop them out.
Once you have all three off and the screws behind the tire are off, slide the whole sideskirt forward and then it will fall free.
Hope this helped yo.
siVix
Aug 11, 2009 10:30 PM
turnsignalandy
11
Feb 23, 2008 06:15 PM
VTEC-DA
Oct 14, 2002 12:27 PM
