TB questions jdm h22 and h23 usdm.
Old Dec 7, 2008 | 03:16 PM
Tizzakowack's Avatar
Default TB questions jdm h22 and h23 usdm.
alright so i have been having a horrible idle problem so thought i would switch out my jdm h22 TB and put on my usdm tb off of my h23. everything went great and noticed this .
the one with the sensor part is the h23 and the other is the h22. i know i put that sensor on a different part on the im. but what can i do. if i try to put on the h23 there is going to be a hose that will not have a place to plug onto.
help me please!!!
Old Dec 7, 2008 | 03:46 PM
could i use the h23 one and plug up that hole where the sensor goes and then plug off that hose that comes from the evap canister?
Old Dec 7, 2008 | 06:38 PM
i was thinking. i could plug the sensor hole so no air gets out and then plug the hole. like i said earlier. and the evap is only for emissions and isnt totally necessary so i dont think i would run into any problems.
guess ill let you guys know how it goes since no ones knows .
if anyone wants to help cuz when i wake up im gonna put it on and see what happens, so anythign by tomorrow morning would be great.
Old Dec 8, 2008 | 07:18 PM
HdeucedeuceA's Avatar
Thats for the MAP sensor. It seems to be an OBD2 TB sence the MAP sensor is supposed to be on the TB. Instead of having it mounted on the fire wall with a vacuum line to the manifold, like the OBD1 ones.
user 720822-1
Mar 29, 2007 02:04 AM
shutta
Nov 28, 2005 07:48 AM
Sabbotage
Sep 28, 2004 08:43 PM
yohan
Sep 14, 2004 04:03 PM
