How to aim/adjust 5th gen headlights?
Old Dec 7, 2008 | 03:11 PM
BB1LOViN's Avatar
Icon2 How to aim/adjust 5th gen headlights?
Hey guys, i was wondering if anyone had pictures of what exactly i need to adjust to aim my headlights down?
I found a little gear like object that says "L/R" but im not sure where the ****/screw is to Lower my headlight beam.
I've read up some threads, some say i use a philips screw, some say an 8mm socket. Is there anyone with an idea/ picture of what exactly does the correct adjustment ****/nut looks like? thanks
Old Dec 8, 2008 | 05:47 AM
Lovemy99Lude's Avatar
I actually just adjusted my 5th gen headlights Friday. I had to use two sizes of phillip screw drivers. On each headlight the top adjuster is the bigger size phillips and the bottom is the smaller. I dont have pictures, sorry. Takes seconds to adjust. Just put the screw driver at 90 degrees into the hole with the plastic gear looking teeth. Turn either L/R to adjust. If I remember the upper gear is for adjusting the headlight left and right and the lower gear is to adjust up or down.
Old Dec 8, 2008 | 09:53 AM
integra15's Avatar
There is a bubble level built into the 5th get lights, use it. Use a phillips head screwdriver to move the gear until the bubble is level with 0.
Old Dec 8, 2008 | 09:43 PM
BB1LOViN's Avatar
thanks for the info guys, yeah i did see the bubble level and also see the lower gear set
ElephantMan13
Oct 29, 2010 12:10 PM
2000h22a
May 31, 2008 11:33 AM
boosted k20
Jun 19, 2005 07:41 AM
civicboy95
Jan 29, 2003 08:14 AM
