lug nuts help
so ive been driving my R now for 4 years and i dont have any wheel locks. i dont want the OEM honda ones since those are very easy to take off.
these will be for my OEM USDM 2000 ITR wheels
what kind can i get? also some that would be compatible with my kosei as well. i use these for when the 2 times i go to the drag strip a year.
thanks.
thanks.
Not worth the hassle and potential PITA when you lose the key.
If you're parking your R in an area where you think your wheels will get stolen you have bigger issues to worry about.
Any thief out to steal wheels will be well aware of how to defeat pretty much any lock you will put on there.
Quoting from the FAQ Topic stickied at the top of the Wheel and Tire forum:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
The "seating area" (or "seat") is the area of the lug nut, and the area of the wheel, that come in contact with each other. Stock Honda/Acura wheels have a ball/radius/spherical shaped seating area, and need lug nuts (such as stock lug nuts) which also have the same shaped seat. Aftermarket wheels use a tapered/conical/cone shaped seating area and need lug nuts (including most tuner lug nuts) which also have the same shaped seat. No, it is not safe to mix and match (stock wheel with tapered lugs or vice versa); the contact between the lugnut and the wheel will be insufficient, putting undue stress on them and potentially causing failure.
But I also agree with sloEL. Wheel theft is not a big concern with ITR's. The reason the cars, and certain parts (e.g. engines) are stolen as often as they are is that they're compatible with most Integras and Civics. The wheels aren't compatible unless the entire hubs are stolen with them. So the chances of the wheels being stolen are much less than for the car itself. If you want to use wheel locks, though, feel free to go ahead; just make sure they have the same shape seat as the wheels.
Don't you think if they have time to steal your wheels, it'd be much easier to just take the car? Seriously I've never heard of anyone having just their R wheels stolen and the car left behind. I wouldn't bother, I'd rather wake up and see my car on the ground or on blocks than not see my car at all.
thanks for all the replyies. i now know what to get now and not mess up my wheels. going to the strip with the stock ITR lugs didnt feel quite right when i was putting them on my kosei.
thanks all
thanks all
nwdave
Jul 31, 2003 11:55 AM
Skeletor
12
Feb 22, 2003 08:14 PM
