Positives Vs. Negatives of Wider Tire.
So currently I am running 16x7 Rota Slips with 205/50/16 Tires.
I was wondering if it is possible to go up to a 215/50/16 or even a 225/50/16.
I figured a wider tire means more contact with the ground which is a good thing.
Are there any positives or negatives to going with a wider tire?
I searched all the wheel and tire forums and threads and couldn't find something that was directly related to this question.
Thanks in advance.
Thanks in advance.
wider tire means more rolling friction, which equals to less power to the ground and worse fuel economy, which is also a result of the heavier tire
but a 205 to a 215 you really won't see a difference and i'll venture to guess that you can go with 215s no question and probably 225s but since i don't know what car or what suspension you're on, i really can't help you
Thanks for the info. Can anyone confirm this?
I don't really NEED to go any wider of a tire. I just figured it would look and perform better since it would fill up the wheel well better and also give for better contact patch on the road.
But again, I know NOTHING about wheels and tires other than basic knowledge.
Hope this helps. Compliments of PZ. http://www.preludezone.com/showthread.php?t=170
4th Generation (1992-1996)
205/55/15 - Stock Size, Recommended 15" Size Tire
205/50/15 - Better Acceleration, Overall Diameter is Smaller
215/50/15 - Larger Contact Patch, Better Acceleration, Overall Diameter is Smaller
225/45/15 - Even Larger Contact Patch, Minimum of 7" wide wheel is recommended, Overall Diameter is Smaller
225/50/15 - Even Larger Contact Patch, Minimum of 7" wide wheel is Recommended
205/50/16 - Recommended 16" Size Tire
215/45/16 - Larger Contact Patch
215/50/16 - Larger Contact Patch, Overall Diameter is Larger
225/45/16 - Even Larger Contact Patch, Minimum of 7" wide wheel is Recommended
205/40/17 - Overall Diameter is Smaller, Not Recommended w/ 7.5" wide or larger wheel
215/40/17 - Larger Contact Patch, Recommended 17" Size Tire
215/45/17 - Larger Contact Patch, Overall Diameter is Larger
225/40/17 - Even Larger Contact Patch, Very Limited Selection of Brands
215/35/18 - Larger Contact Patch, Small Profile means Less Protection for Wheels
215/40/18 - Larger Contact Patch, Overall Diameter is Larger
225/35/18 - Even Larger Contact Patch, Recommended tire size for 18x7.5" with at least a +48mm offset
225/40/18 - Even Larger Contact Patch, Overall Diameter is Larger, Not Recommended if car is Lowered
Thanks dk4ever! And everyone else for that matter that responded.
If I were to go up to a 215 I would have to get a 45 series...so...what would be the minus to that? Anything? I know its a smaller sidewall...but anything else to be aware of?
Only reason I am asking about all this is I can get a good deal 215/??/?? tire.
a 215/45/16 would only be slightly smaller though so you wouldnt even notice the difference really. Im on 205/45/16 which is a good bit smaller than stock size and I dont notice much difference if any. Youll be fine with the 215.
You should note that, in general, tire size does not affect the size of the contact patch, only the shape (however sidewall stiffness will also affect the size of the contact patch, hence the qualifier). All else equal, the only way to affect the size of the contact patch is to alter the air pressure in the tire or alter the weight of the car.
here is how it looked
here you can see the wheels tucked in just right
car is fs now
ok. so ya, you could do 215 or 225 all around if you wanted. I had 215's all around on my 17" bbs rc's, and the car handled pretty nice even before the gc/koni setup I added.
However, if I was setting up a prelude to be fast from scratch, I would choose narrower tires in the back instead of using a firm rear suspension to get the car to rotate. Generally Americans will use a stiff rear suspension, which works, but can be a pain on the street. The Japanese tuners(take a look at the JUN car or any spoon civic) use narrower tires in the rear, so the rear is more likely to lose grip sooner relative to front, reducing(or eliminating) understeer.
Now I wouldn't say you should use 235front, 215 rear like JUN does on their heavily modified lude, but you should consider going staggered if you plan to do autox or anything similar. Staggering tires is a big deal over in the s2k forum, but here nobody talks about it. Figured I'd throw it out there.
good luck,
mike.
good luck,
mike.
I just drove the mountains of Dahlonega, Georgia in my SH with 205/50-16" tires. I ripped the car up and down the tight twisties and it was amazing.
Going to larger tires may give you more roadholding, but will you be sacrificing other things like feedback and chuckability? I've been telling my friends that Preludes are Japanese Lotuses. They are not the most powerful, fastest or skidpad champs, but they speak to you (something missing from 92% of cars out there).
I say buy the gummiest/best tires in your size.
Looks like I will be getting 205/50/16's again.
Doesnt seem to be any positives to getting a bigger tire.
Unless some great deal comes along.
Thanks for everyones input. If someone else has an arguement for why it IS better to go bigger I am not getting tires for another week or so...feel free to chime in.
Also, if anyone knows of a good tire on sale currently if you could PM and link me or link me here. Thanks
Try this site out to give you a good idea of how changing your tires is going to look and perform http://www.miata.net/garage/tirecalc.html
225/50/16 Falken Azenis 615 on 40mm offset Rota Slipstreams rub in the front in the wheel well when the suspension is significantly compressed and you've got a lot of steering input. I'm not just giving my opinion. I've got experience.
Of course if you have shocks with better compression damping and stifer springs then it probably won't be an issue.
Pirate
Everyone be nice to everyone else please. No name calling or being disrespectful to each other.
It was merely a simple question...nothing to argue about. We all have the right to have differing opinions...its really ok.
<3
<3
Positives: Wider tire = slightly bigger contact patch = slightly more traction
also, a wider tire gives more rim protection for people who can't drive and tend to rub curbs.
Negatives: Wider tire = more expensive, heavier, increases odd of rubbing, and usually results in incorrect spedometer reading due to not having same overall circumference.
Exceptions do exist.
