Suspension & Brakes Theory, alignment, spring rates....
Will 10.3" front rotors fit on rear?
Old Dec 7, 2008 | 09:32 AM
JohnnieChimpo's Avatar
Default Will 10.3" front rotors fit on rear?
When I compare them the hub on the fronts is smaller. Does anyone know if the 10.3 front rotors will fit on the rear hubs?
Old Dec 8, 2008 | 11:28 AM
Katman's Avatar
No they won't because the hat's height offset isn't the same neither is the thickness of the rotor as well.
But, there are factory rear 10.3" rotors found on the 02-04 EP civic Si that are compatible with 4x100 honda's. Only thing, is you need to get the right caliper to use these rotors.
ITR or CRV rear calipers are key to use. You can get away with EP/DC5 rear calipers as well, but they don't mount the hand brake cable very cleanly like ITR or CRV calipers would.
Old Dec 8, 2008 | 12:38 PM
kommon_sense's Avatar
Katman is correct. 02-04 ep3 rears are 10.2". Cost about $13/ea. Fit right on as they are 4x100.
On a side note. I have a set of ep3/rsx rear calipers with the correct hardware to mount up the stock e-brake cable. They are for sale.
I also have a set of ITR rear calipers for sale. Pm if interested.
Old Dec 8, 2008 | 07:45 PM
If using nsx rear calipers, then I believe you need the thicker vented rotors. However I'd advise against nsx rears. Thats way too much rear brake one a civic/integra.
eg6noise
Suspension & Brakes
May 28, 2019 04:21 AM
NXSpoon
May 8, 2007 08:43 AM
SOHC_me
Oct 9, 2006 01:51 AM
gldndrgn14
May 10, 2006 02:02 PM
Turtle
Oct 9, 2002 09:37 AM
