95 Integra LS quit running HELP!!!!!!
Well, my starter has been out for a while so i have been compression starting it. Then it would not start after being parked for a couple of days.... I know it has fuel cause i disconnected it and turned it to the on position. So if its electrical, what should i check? Thanks
i wouldnt go buying part before you know wats wrong id start with the starter first then check for spark. Then take a multimeter and test you coil and icm before you go buying part if i remember a coil and icm tip the scale over $100.
