this soft brake pedal is driving me nuts-- i need help...
Old Dec 6, 2008 | 06:17 PM
starbai's Avatar
Default this soft brake pedal is driving me nuts-- i need help...
I recently did a Legend type 2 caliper conversion on my 92 Prelude Si. Did this when I did my 5 lug conversion.
Ever since, the brake pedal has a lotta play very soft.
I bleeded the brakes several times, with no luck. Then I had the dealer bleed it while it was in there for a few other things... still soft.
What can I do? What needs to be upgraded, what else can I do to just get rid of this soft pedal??
I will try steel lines but i have been told the difference will be minimal if anything.
If replacing master cylinders or other parts are whats in order to fix this, could you all recommend brands if aftermarket, or tell me where I can get the parts that I would need?
I'd really appreciate the help
Old Dec 6, 2008 | 07:09 PM
LobeSex's Avatar
i would think changing the master cylinder should do it...kinda sounds like its not getting enough pressure
Old Dec 6, 2008 | 07:19 PM
starbai's Avatar
is there any such thing as an upgraded cylinder to pprovide more pressure?
i wonder if using a legend's master cylinder is possible?
Old Dec 6, 2008 | 07:29 PM
LobeSex's Avatar
possible...worth a shot if thats not it atleast u got a new one and dont have to worry about gettin a new one soon...and that also eliminates one thing it could b
Old Dec 6, 2008 | 07:56 PM
gutted-dx's Avatar
Smaller the master cylinder = more pressure. Not sure what your options are.
Old Dec 6, 2008 | 08:04 PM
starbai's Avatar
just by searching on ebay... I've found some information but I'm not sure what it means so I need some help here...
Replacement Prelude master cylinders are routinely listed at 15/16" bore. (not sure which part on the cylinder thats refering to)
Replacement Legend master cylinders are routinely listed at 1" bore...
is that difference too large to work??
Old Dec 6, 2008 | 08:07 PM
LobeSex's Avatar
its slightly bigger than the prelude replacement so i wouldnt go wit that one it would prly get worse lol
Old Dec 6, 2008 | 08:18 PM
starbai's Avatar
ok then, so i'll stick to the prelude cylinder (cheaper anyway)
is there any way to actually TEST the master cylinder before i go and blow the bucks on a new one?
Old Dec 6, 2008 | 08:29 PM
LobeSex's Avatar
not sure....did ur mechanic look for any small leaks on any hoses?
Old Dec 6, 2008 | 10:54 PM
SOHC_4dr's Avatar
check your break pedal free play to. its a good check up to do. it could help
Old Dec 6, 2008 | 11:06 PM
MLBZ521's Avatar
I'm assuming by "Legend type 2 caliper conversion" you're referring to the Legend GS 2-Piston Calipers..
Few Questions:
What Rotors are you using?
You put on new pads I'm assuming also?
Not loosing Brake Fluid are you?
If you wanted to try a new Brake Master Cylinder and try more pressure, your best bet would be a Prelude S Model.. I think they're smaller.
Old Dec 7, 2008 | 06:26 AM
starbai's Avatar
Yes the 2 piston calipers from the type-II legends.
I'm using brand new brembo blank 28mm rotors (made for Legend calipers)
Yes brand new Axxxis Pads.
Old Dec 7, 2008 | 09:12 AM
h23prelude's Avatar
when you bled the calipers did you make sure that the caliper bleed port was facing up while bleeding, its necessary to remove a caliper bolt and flip the caliper upwards to get the bleeder facing up. dont forget to use a 2x4 or similar to let the caliper squeeze while bleeding.
is your brake line getting kinked, or squeezed anywhere?
when you re-installed your brake lines did you use NEW copper crush washers?
usually a master cyl will slowly sink to the floor, if this is occurring then its most likely a master cyl
also check if your getting proper vacuum to the brake booster, check the one-way-valve on the brake booster, use a vacuum tester to check the brake booster for leaks.
Old Dec 7, 2008 | 10:29 AM
starbai's Avatar
the needle was facing up beacuse i swapped them, the legend's left caliper is on my prelude's right side and vice versa.
my brakes aren't sinking to the floor, you just have to push them in probably about an inch before the car actually starts responding
Old Dec 7, 2008 | 11:11 AM
h23prelude's Avatar
try crawling under your dash and adjusting the pedal linkage to the master cyl, it almost sounds like there's too much play there, there should be a lock nut and a little fork that attached to the pedal.
if not then the master cyl could be sticking, but tha'ts very rare and you would most likely feel your brakes slightly dragging
Old Dec 7, 2008 | 05:40 PM
starbai's Avatar
dont you need some kind of special tool to adust the lock nut on the pedal?
(i'll of course confirm for myself in the morning)
Old Dec 7, 2008 | 06:02 PM
h23prelude's Avatar
i dont think so, i believe its 2, 12mm bolts jamming against each other. but i could be confusing it with the clutch petal adjustment.
best of luck
starbai
Suspension & Brakes
Dec 8, 2008 02:12 PM
gearhead313
Sep 17, 2007 09:44 AM
ejcivicdee
Suspension & Brakes
Apr 11, 2007 07:56 PM
903
Jan 31, 2006 01:23 AM
RedEK9
Suspension & Brakes
21
Feb 8, 2005 05:28 PM
