odometer, speedometer failed on '91 Accord
Old Dec 6, 2008 | 04:08 PM
bhome83's Avatar
Default odometer, speedometer failed on '91 Accord
hey guys, new here and this is my first post. I'm a pretty big novice when it comes to cars so bear with me here
My '91 accords odometer, trip meter and speedometer have gone out. They occassionally start working again but for only about 1-2 min. they die on me. I also have a red service engine light and a green 'sport mode' light that contiuously blinks. All this happens at the same time
I could go see an auto tech but sounds like this could be just a case of a short in a specific wire and dont want to spend $100 bucks for an auto person to tell me that.
Any ideas on how to fix this? If worse comes to worse i will have to have someone do it for me but trying to save $$$ so any help be appreciated. I'm assumming i just have a short in a wire(s) somewhere but not sure if it is easily accessible.
Thanks!
Old Dec 6, 2008 | 04:27 PM
redbull-1's Avatar
It is either a loose connector to the Vehicle Speed Sensor (VSS) or the VSS needs replacement.
See below link regarding the VSS:
http://techauto.awardspace.com/vss.html
Old Dec 6, 2008 | 06:43 PM
P_Adams's Avatar
I agree. You've most likely have a Vehicle Speed Sensor (VSS) starting to fail. It's not uncommon. It's mounted to the Transmission and looks like this:
Cheers!
P
Old Dec 6, 2008 | 08:44 PM
bhome83's Avatar
im hoping its a lose connection as i can just tighten the screws. I'll check under the hood tomorrow and report back if that is the case. If it needs replacement is this something i can easily do (considering im a novice when it comes to cars?) How expensive is the part? Thanks guys.
Old Dec 7, 2008 | 09:23 AM
turboH22Aakkord's Avatar
like these guys have already stated, its probably the VSS and if it isnt just a "loose connection" the VSS isn't all that expensive to replace... Example:
http://cgi.ebay.com/ebaymotors/91-19...Q5fAccessories
Old Dec 7, 2008 | 04:03 PM
quizbo99's Avatar
I bought my VSS from EBAY and it works great ($15 + shipping). I changed it out in about an hour. The bolt closest to the motor was easy to remove but the one on the fend side was a bit tricky. 2 bolts is all holding it in and yes you can do it.
Old Dec 7, 2008 | 04:58 PM
craiger28's Avatar
I have the same car. I also have an odometer not working, "S" light blinks and CEL on. Once you replaced the VSS did the CEL go off? How about the "S" light? Thanks.
Old Dec 7, 2008 | 06:00 PM
YeuEmMaiMai's Avatar
if the VSS was the problem, the CEL should clear, blinking S light = problem with transmission or TCU
Old Dec 7, 2008 | 07:48 PM
bhome83's Avatar
so the "s" light blinking has nothing to do with the VSS? not a good sign if its the transmission. Seems weird though because the "s" light started blinking only a day before the odometer and the "check engine" light started malfunctioning.
didn't have much time to check extensively under the hood today to locate the VSS, but i did look for a minute or two and didn't find it. Must be blind, where exactly is this VSS? When found, should i just first tighten the screws? thanks guys
Old Dec 7, 2008 | 08:15 PM
redbull-1's Avatar
The VSS can cause the S light to blink.
Refer to the link I previously posted above.
Old Dec 7, 2008 | 08:35 PM
P_Adams's Avatar
True, The TCM utilizes the Vehicle Speed Signal; along with other inputs to determine the shift point matrix. It's probably only one of several sensors which can set both warning lamps
P
Old Dec 7, 2008 | 08:38 PM
JAY DEE EM YO's Avatar
P
Agreed P adams is the man... Heed his gospel he knows what he is talkin bout!
Old Dec 8, 2008 | 03:27 AM
91EX4dr's Avatar
Look for that sensor under the dist cap, under thermostat housing and on the top of trans. Took me about fifteen minutes to replace. Got one from ebay as well and works fine, 20k miles later.
BTW, my S light went on when the vss was the problem.
Old Jan 17, 2009 | 09:56 AM
bhome83's Avatar
Default Re: odometer, speedometer failed on '91 Accord
sorry to bump such an old thread guys but this is a continuation of my original post. So anywho, I looked like crazy under my '91 accord hood and could not find the the VSS. My dad (who knows a lot more about cars then me), couldn't find the VSS as well. We found the distributor cap, but for the life of me couldn't find this VSS. How big is it? I could just buy one off ebay and look for it, but I would like to find it first. I might have to take a pic of my car and post it on here. Didn't think it would be this hard to find....
Old Jan 17, 2009 | 11:28 AM
redbull-1's Avatar
Between the throttle body and the distributor (on the left side of them), look down all the way to the transmission (large silver body), there will be an electrical connector plugged into it. The VSS size is about 1 inch across (look down about 1.5 feet). The link I posted previously shows the general location on top of the transmission.
Old Jan 17, 2009 | 09:07 PM
bhome83's Avatar
alright, will try tomorrow in daylight. So is it easily accessible and replaceable from the top of the car or do i need to go under? thanks!
Old Jan 22, 2009 | 06:37 PM
bhome83's Avatar
alright, well i must be really blind cuz I cant find the VSS. I took a pic of my '91 Honda Accord under the hood. Take a look, and if someone could tell me where the VSS would be, that would be great! I took 3 diff. pics, kinda showing where I'm looking in the second two pics...
Thanks!
Old Jan 22, 2009 | 07:47 PM
redbull-1's Avatar
It's a little further back under the air intake tube area. Look down past the air intake tube.
Old Jan 22, 2009 | 09:12 PM
TheMuffinMan's Avatar
He knows where you live!
bleh too tired to read right
Old Jan 22, 2009 | 09:37 PM
bhome83's Avatar
and the VSS is easily replaceable from the top of the car, or do i need to go under? thanks! ill give it a try again to see if vision is better
Old Jan 23, 2009 | 09:07 AM
redbull-1's Avatar
You remove it from the top. Remove the air intake duct. Then use a socket extension with the socket and ratchet. A jointed socket or jointed ratchet might make things a little easier; but, you can do it without it.
Here is the Autozone instruction for removal of the VSS (which are from the Helms manual BTW):
http://www.autozone.com/addVehicleId...00c1528005f99d
Old Apr 25, 2010 | 07:10 AM
MRAJB's Avatar
I just got my VSS out of the car yesterday. I didn't realize you need to remove it from the metal bracket before being able to unplug the electrical connections. I need to buy a new VSS, does any have experience with the ones on ebay under $20?
91POSAccord
Mar 12, 2007 06:54 PM
fry_guy12
Jun 5, 2006 08:32 AM
oahu
Sep 6, 2005 04:57 PM
Monty
Sep 28, 2002 08:56 AM
