Shell,aem,act,turbo,intercooler,fully built B16A motor and more
Old Dec 6, 2008 | 04:00 PM
streetdemons's Avatar
Default Shell,aem,act,turbo,intercooler,fully built B16A motor and more
close thread plz
Old Dec 6, 2008 | 05:45 PM
hai_tech's Avatar
bump for DuMa lol
Old Dec 6, 2008 | 08:54 PM
bump
Old Dec 9, 2008 | 07:15 AM
Originally Posted by streetdemons
testing water:
looking to get rid of my fully built b16a complete swap with turbo kit
mods:
pr3 mild port head and port match JG intake manifold with 65mm bullfrog throttle body
brian crower valve trains and retainers
usdm ITR intake cams and usdm gsr exhaust cams
manley stock sized valves
aem fuel rail
aem drag fuel pressure regulator
precision 1000cc injectors peak n holds
three angle valve jobs
block:
b16a bensen full sleeved 84mm
84mm cometic head gasket
je 8:2:8 compression piston
brain crower I-beam rods
micro polished crank blue print balance
arp headstuds
type r oil pump
oem si water pump
kingston race bearings
6 qaurt moroso drag oil pan with drag oil pick up
transmission:
usdm type r lsd 4.4 final drive trans
8lbs act flywheel
act extreme 6 puck clutch kit
no gring garuntee
turbo kit: custom
gt30r 4 bolt 63ar dual ball bearing turbo
fludyne radiator is also included because coolant lines are tap for turbo
equal length ram horn turbo manifold
38mm chrome tial wastegate
gm 3bar map sensor
manual oil pressure gauges
hks blow off valve
pippings are mad by chuck boost factory
750hp precision intercooler huge
i use 20-50 royal purple oil
tuning:
obd2-b AEM EMS
motor is fully tuned at DB performance by shane
motor put down 448WHP and 280 tourqe on E85 at 20lbs boost
motor pulls crazy hard and still have alot in it
but must sell do to another crazy project of mine so i have to let this one go in order to complete my next project.
im asking for $6500.00 complete swap with turbo kit and AEM EMS
what im selling is not for the car...only the swap...will sell the whole car for $8500.00
97 hatch championship white paint job rolling on a set of 16inch rota slipstream gunmetal...tires are g-force bfgoodrich with 90% threads left..if interested in car i will post pix up...car is also gutted out and have only 2 red jdm recarro seats in it...open to trades as well...shot me offers...
i can be reached at loyalkonyang@yahoo.com emil for more imformation
PIC:
jwcarson114
Dec 31, 2012 01:26 AM
1sicef9
Jul 13, 2010 08:24 PM
b16bri
Jan 4, 2009 11:22 AM
civicjdmb16a
97
Oct 1, 2007 06:29 PM
fernancivic
Jan 21, 2005 04:30 PM
