99 prelude puts at idle any ideas
Old Dec 6, 2008 | 01:36 PM
jthrasher1's Avatar
Default 99 prelude puts at idle any ideas
i got a 99 prelude car starts right up idles fine when cold but when it warms up putts out the exhaust any ideas thanks...
Old Dec 6, 2008 | 02:55 PM
preludefan's Avatar
[QUOTE=jthrasher1;36620990]i got a 99 prelude car starts right up idles fine when cold but when it warms up putts out the exhaust any ideas thanks...[/QUOTE
does it idle below 1000 rpm to where the oil light flickers?
Old Dec 6, 2008 | 04:17 PM
mattsnooz's Avatar
car should idle below 1000 normally at around 800. Sputtering or "putting" I think is poor combustion. I noticed if i retard my timing too much it sputter's aswell.
My mind tells me to check ignition timing first. Check spark plugs too, see if your detonating.
Ofcourse a sound clip would help huge. I figure its just the typical sputtering though
Old Dec 7, 2008 | 08:44 AM
jthrasher1's Avatar
well the car idles at 800rpm no blinking oil light and my cel light is on now and the code is p0302 cylinder 2 missfire thats the only code ... the car has new plugs and wires what else could it be and what should fix the problem...
Old Dec 7, 2008 | 01:35 PM
jyracer's Avatar
mine is doing the same but all 4 of mine are doing it. i would like to know too
Old Dec 8, 2008 | 07:33 PM
duanes's Avatar
Make sure that there is no "dust" inside the distrib. cover. If there is a grey or black dust, clean the cover and rotor bug thoroughly. It is carbon and will short the spark. You get all kinds of idle and acceleration problems with this and it will often show up as a cylinder misfire.
Also - check compression, all cylinders should be reasonably close together (maybe 10-15% between highest lowest) and all should be above 110 psi or so, I believe.
May also be spark gap on that plug or a bad injector. If money is tight, swap injector to different cylinder and see if problem moves.
ut01preludesh
Jul 8, 2011 10:30 AM
IA95civicDX
Nov 18, 2010 10:19 PM
invasian_boy
Aug 31, 2009 11:42 PM
jwill9500r
Sep 3, 2006 06:56 AM
tarheelsoldier
Jan 27, 2005 11:02 PM
