climate control
climate control is turning on and off by itself, sometimes when i hit a bump it will turn off, it rarely works at all though. car is a 2000 civic
thanks for your help
If it turns on and off when you hit a bump, it is likely a loose connection somewhere. Did you recently take something on/in your dash apart?
no, i bought it a couple months ago and was like that. it doesn't constantly come on and off every bump. very rarely and mostly it'll just be on 1 day and off the next week.
Sounds like a loose connection or a bad/shorted wire. If you pull the little open compartment below the climate control out you can probly get a couple of fingers in there and wiggle the clip around and see if it cuts on and off.
Well idk how much a new harness is but i would check the old one, turn everything on and wiggle it around everywhere. Eventually ur climate control will start cutting in and out and theres ur bad spot. Also check your fuses and make sure a previous owner didnt bypass the fuse or sumthin like that.
