spark plugs
Old Dec 6, 2008 | 07:49 AM
jyracer's Avatar
Default spark plugs
ok what is the down right best spark plug for my 5th gen? and what should be the gap on them?
Old Dec 6, 2008 | 08:05 AM
G2IntegraGS's Avatar
Well do you want performance or long plug life? Search and you will find the info you need to make your own choice. I use NGK v-power. Some people like platinum or iridium since they last longer. I belive the stock plug is the NGK platinum.
Old Dec 6, 2008 | 08:11 AM
jyracer's Avatar
i want performance and does anyone know the gap length?
Old Dec 6, 2008 | 08:21 AM
Kronn 98SH's Avatar
NGK Iridiums, and don't worry about the gap. All the NGK's I've seen come pre-gapped at .044, which is what a stock prelude engine should run.
Old Dec 6, 2008 | 08:25 AM
jyracer's Avatar
k man thanks. cuz im pretty sure mine are fowled and thats whats causing me to bog down
Old Dec 6, 2008 | 12:51 PM
E-Money's Avatar
i recently checked majestic honda because i was gonna make a order. platinum and copper are the same price!
Old Dec 6, 2008 | 01:06 PM
dudeitsahonda's Avatar
v-power isn't pre-gapped like the iridiums or platinum
Old Dec 6, 2008 | 01:10 PM
Kronn 98SH's Avatar
To OP, make sure you get the correct pre-gap if you purchase platinums or iridiums. You can't gap those plugs afterwards.
Old Dec 6, 2008 | 06:38 PM
duanes's Avatar
OK - I'll bite - Kronn - How did you back flip your 98 Prelude S?
Old Dec 6, 2008 | 08:09 PM
Kronn 98SH's Avatar
88 Prelude S
I was cruising at 80 on the highway, hit an oil/water mixture on a curve, rear end started sliding out of control, went backwards into a ditch, flipped backwards, landed upside-down, and slid for 100ft in the mud. The top of the car was smashed down all the way to the top of the steering wheel. I crawled out without a scratch until I kicked myself for only having liability insurance.
Old Dec 6, 2008 | 11:25 PM
pesater's Avatar
no, the Iridiums aren't pregapped, I had to use the feeler to extend to 1.1mm
Old Dec 7, 2008 | 07:16 AM
Kronn 98SH's Avatar
Yes, the Iridiums are pre-gapped. Look around and you'll find that to be true. And I sure hope you mean 0.11mm (or 0.044in). Lastly, using a gapper on these plugs can damage the iridium (or platinum) tips, causing poor or no spark.
91akira
Mar 12, 2010 08:23 AM
nickolas388
Oct 26, 2005 08:01 PM
Chiller
Oct 29, 2004 08:18 AM
DeL SLo
Jun 8, 2002 08:28 PM
mattmw88
Feb 22, 2002 07:54 AM
