air/fuel ratio gauge help
Old Dec 6, 2008 | 07:44 AM
801ef's Avatar
Default air/fuel ratio gauge help
searched but could not find, i am wiring up an a/f gauge in my friends 02 dc5 but ive never dealt with a 02 sensor with more than one wire lol the 02 sensor before the car has i believe has two black wires,two white, and one green, would the sensor for the a/f gauge be spliced into the green?
also we are going to be wiring up an oil press. gauge however since i am not familiar with k series motors and we have no manual and appearently i cannot search on search engines cuz "keywords" never make sense, i was wondering if someone could post a pic of where it is located on the motor.
any and all help appriciated!
Old Dec 6, 2008 | 08:14 PM
801ef's Avatar
anyone?
Old Dec 6, 2008 | 08:37 PM
LobeSex's Avatar
r u using a wideband o2 sensor? or stock?
Old Dec 6, 2008 | 09:32 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
If you are putting a lame a/f gauge from autozone or anyother parts store your wasting your time. They are so inaccurate. If you want flashy lights then put in flashy lights.
What kind of a/f gauge are you installing?
Old Dec 6, 2008 | 09:36 PM
JAY DEE EM YO's Avatar
should be white wire for a/f gauge. As far as o/p gauge on a K you on your own.
Old Dec 6, 2008 | 09:40 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
and you should only have 4 wires. Two black, white, green. Blacks are ground. I believe the white is for the heater circuit. Green is the one you want...
I have an 05 and my primary had two black, one white, and one blue.
Old Dec 7, 2008 | 12:57 AM
801ef's Avatar
ok so they are glow shift gauges my friend wanted to try out, we are using a stock o2 sensor, and im on my own with o/p gauge? so does that mean no one knows where the stock sensor is? and alright i will use the green wire for the signal for the gauge
Old Dec 7, 2008 | 07:59 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Well to install the oil pressure gauge you just take out the oil sending unit and buy a Tee and tap the block from there.
What do you mean "so does that mean no one knows where the stock sensor is?"
Old Dec 7, 2008 | 09:20 AM
LobeSex's Avatar
all i know is if u r using a stock 02 sensor it is gona b totally inacurrate and a waste of time...tell ur friend to get a real wideband set...
http://www.innovatemotorsports.com/products/MTS.php
Old Dec 7, 2008 | 09:25 AM
mcmotors's Avatar
+1, real WB is the way to go.
1 wire, 3 wire and 4 wire O2 sensors and gauges are only accurate at 14.7/1
You'll have one wire for the 0-1v output, the other two or three wires will be for a heating element.
Innovate makes nice stuff.
Old Dec 7, 2008 | 11:46 AM
square_1's Avatar
Wideband is the way to go. Don't waste your time.
Old Dec 7, 2008 | 12:21 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
technically the RSX 02 sensors are wideband already just to let you know if you didn't already. If he gets k-pro he doesn't need an a/f gauge.
Old Dec 7, 2008 | 12:25 PM
DaveSi677's Avatar
Wideband is the way to go... I agreed!!!!!
Old Dec 7, 2008 | 04:19 PM
I dont think his friend is "into" knowing what his car is actually doing, i think he just wants flashy lights. The guages DID come from the zone....
Old Dec 7, 2008 | 04:30 PM
LobeSex's Avatar
lmao damn flashy lites!
Old Dec 7, 2008 | 07:18 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
wow what a cool guy. Well hope he enjoys his Rice. Am I to assume a universal triple gauge pillar pod too?
TrademarkAccord
Jul 20, 2014 04:54 AM
JDM1civic
Apr 8, 2007 08:10 AM
TheJediMex
Apr 30, 2006 06:25 PM
mehdiR
Aug 23, 2005 07:32 AM
