96-97 cargo net?
hey guys, i found a cargo net for 96-97 accord. my car is 95 ex. did the 94-95 accord use cargo nets? and if not, do you think the 96-97 accord cargo net would fit in my car? i don't know anything about cargo nets.
The cargo nets were a Honda accessory. The part number for the cargo net for the 94-95 Accord was 08L96-SV4-100, while the part number for the 96-97 was 08L96-SV4-100F. I don't know the main difference in the two slightly different part number.
If you want to see the installation instructions for the 96-97, see the following link:
http://www.collegehillshonda.com/ins...d/cargonet.pdf
From the instructions you should be able to tell whether it can fit your 95.
You may be up against a part number supersession (same kit / different part number). The only possible issue I could think of would be the net's anchor mounts, since I can't envision much difference in the trunk finish panels.
P
P
thanks guys, thats what i was thinking. (same part different number) anywho, i'll just check out the installation of it in the 96-97 and figure it out. i'll let you guys know what i think later.
LasloNimne
Mar 31, 2003 04:14 AM
