2003 Honda Accord Radio does not work
I recently bought a 2003 honda accord the cd player works fine but the radio does not work on either the AM or FM. We have already checked the connection and nothing seems to be wrong. The sound I receive is just static. I would appreciate any ideas on possible ways to fix it. or if anyone has had this same problem. Thank you.
Did you check that main fuse I told you about. I know on my 08 car that I pulled the TMPS/Traction control fuse so I could run without traction control, and since it was a combination fuse that had several systems on a single fuse unit(different fuses integrated in on unit) I had the misfortune of having a radio that turned on... but I could not hear anything. It probably controlled the amp
Yes, from the beginning the radio has not worked but the CD player works fine. When I switch to play radio FM or AM there is only static and in some you can hear just a little talk. As I said we have traced the connection from beginning to end and pulled the radio out and in. Yes, the back window is tinted.
ndzodzo
69
Jun 26, 2019 05:49 AM
Smurfitchy
Apr 16, 2017 05:22 PM
leeanne
Nov 4, 2012 07:12 PM
greenhonda29
Dec 2, 2008 12:34 PM
michael10706
Mar 18, 2008 04:03 PM
