Noise coming from brake pedal
whats up everybody, Im here cuz I need help diagnosing whats wrong with my car's brakes. Any help would be much appreciated Thanks heres a video of what Im talking about.
thttp://www.youtube.com/watch?v=eEl61qPQnwo
When it makes the nosie does it affect the cars abbility to break?
WHen it makes the noise is the pedal any harder or easier to push down?
Wat casued the problem?
Do you have abs?
It it a buzzing or rattling?
Your pedal seems like it has a lot of travel
Do you have abs?
No it doesn't
it is easier
It started after the brakes pads got changed
It is a buzzing
If by -pedal seems like it has a lot of travel- you mean it goes in to far, I think it does.
it is easier
It is a buzzing
well that is a lot of travel id bleed the line and make sure you have enough brake fluid. Chek the abs module if that turns up nothing you mite have a bad master cylder. Before you replace it just check with a mechanic to be sure. The noise sounds like the abs. I havnt delt with brakes a lot but imo if bleading and toping off the brake fluid and a good abs module do nothing it really only leaves your master cylider
