12v switched under hood
where can I tap into 12v switched source under the hood? I want to add an accessory that needs key on power. I dont want to cut into the wiring harness if i dont have too.
It depends on the accessory. If you tap into another electrical circuit, you may draw to many amps and blow a fuse. If you were to use a switch, you could use the power wires at the fuse box under the hood.
SpOoLiNg CiViC
Jan 4, 2007 11:23 AM
Si
Audio / Security / Video
Apr 6, 2002 12:34 PM
