b18c1 compression test results
Old Dec 5, 2008 | 10:21 AM
thedudefromjerz's Avatar
Default b18c1 compression test results
in my ef i have a b18c1 stock block with b16 head stock also. I did a compression test and i was jus wondering what you guys think of the results,
With throttle closed (forgot to open it) i got
no 1 cyl 190
2 cyl 165
3 cyl 185
4 cyl 185
with throttle open i got
1 cyl 140
2 cyl 150
3 cyl 195
4 cyl 160
I know you suppsed to do the test with throttle open but i forgot so theres the results with it open and closed. What you guys think.
Old Dec 6, 2008 | 09:35 PM
B18c1vicrx's Avatar
i know a stock gsr motor should be pulling at least 225, i dont think the b16 head should change the compression (but i could be wrong), but the car should be warmed up when doing these tests, did you warm it up?
Old Dec 6, 2008 | 10:14 PM
soodominican's Avatar
the car should be warmed but its dangerous cuz u might strip the head taking the spark plugs out, anyway i don't think ur valves are bent because the compression would be lower but they may need adjustment.
Old Dec 6, 2008 | 10:19 PM
Jonknee's Avatar
I agree with dude above me.
Old Dec 7, 2008 | 09:47 AM
Yes I did do the test with the car fullwarmed up. Also I adjusted the valves about 2 months ago but ill check them again. Also does anybody know how much air to apply to each cylinder on a leakdown test for this motor?
Old Dec 9, 2008 | 06:30 AM
B18c1vicrx's Avatar
no more then 90 psi i believe, or something around that...but your starting leakage reading should be 0 regardless of however much air your putting in, also did you try a wet compression test to check the piston rings?
Old Dec 9, 2008 | 05:29 PM
I didnt try the wet compression test im going to do it tomorow morning along with the leakdown. Im using a homemade leakdown tester btw that i made. Hopefully i dont blow up the motor.
Old Dec 10, 2008 | 08:56 PM
doeboi365's Avatar
hey guys i did a compression test too on my 2000 si its a b16 motor and im pretty much ready to say that the car is barley hanging on to life.its a rebuilt title sooo the mileage on the car my seem incorrect i bought the car at 95k and its at 105k
the numbers are.
1 cyl 180
2 cyl 150
3 cyl 175
4 cyl 135
can u guys help me out i dont know wat could be wrong...
Old Dec 10, 2008 | 10:15 PM
red_EF9Si's Avatar
Not sure if this helps, but I recently did a comp test on my JDM B18C and got the following results:
1-225, 2-230, 3-230, 4-230
I was told this was a very healthy motor by the shop.
Leakdown test was 98% sealed.
Old Dec 11, 2008 | 06:31 AM
doeboi365's Avatar
ya i know my numbers are tooo low i may need a new block...or a motor rebuild
Old Dec 11, 2008 | 09:39 AM
gutted's Avatar
with the b16 head on a stock gsr block, compression should drop 0.2 so it should be at 9.8:1. do the cylinder leak down test wet & dry as it'll tell you which internal part is causing the lower compression IE piston rings, intake valves, exhuast valves, bad headgasket\warped head
Old Dec 11, 2008 | 04:36 PM
the numbers are.
1 cyl 180
2 cyl 150
3 cyl 175
4 cyl 135
your in the same boat as me
Old Dec 11, 2008 | 04:47 PM
Isnt us gsr compression ratio 10.6:1?
Old Dec 13, 2008 | 01:42 PM
B18c1vicrx's Avatar
10.1 i believe
Old Dec 15, 2008 | 08:15 PM
doeboi365's Avatar
well i guess the leak down test should be able to let me know wat else can be wrong with the block... even tho im not leaking anywhere...i burn oil fast tho...
KYDelSol
Mar 28, 2013 03:16 PM
lee0149
Feb 6, 2009 10:33 AM
IntegraType-R
Jan 20, 2007 06:07 PM
GODSPEED33
Dec 22, 2006 06:04 AM
lazyguy
May 5, 2002 01:36 PM
