H22A block, H22A4 Head w/A4 head gasket.
Old Dec 5, 2008 | 09:59 AM
JBirch_97Prelude's Avatar
Icon2 H22A block, H22A4 Head w/A4 head gasket.
The shop finally got my Engine running but it is having trouble idling. Could it be because of the H22A4 Head Gasket i'm using. Recently I was advised to use a H22A Head Gasket. Last cold compression test were mid to high 100's. Engine had no problems before the timing belt snapped!
Old Dec 5, 2008 | 11:06 AM
98vtec's Avatar
moderator emeritus
you should always use the headgasket designed for the block.
Old Dec 5, 2008 | 11:22 AM
Prudz_lude's Avatar
i have a h22a headgasket you could buy off me. $50 and it is yours. It is from honda. I ended up buying a h22a4 block so i bought an a4 gasket and have this one sitting in my room collecting dust.
Old Dec 5, 2008 | 03:44 PM
I have a head gasket. Could that be the problem? It run great, but it is not idling once it reaching operating temp. I need a new Dizzy also, OBD1!
Old Dec 7, 2008 | 09:12 AM
Bump!
superturboprelude
Dec 18, 2008 08:44 AM
superturboprelude
Dec 17, 2008 03:42 PM
slowcrx954
Jan 2, 2008 07:43 AM
wheelmaneg6
Jun 5, 2006 09:58 PM
jsprelude
Jun 18, 2005 07:43 AM
