f/s all motor b stuff good list of parts
B16 Head- milder Ported and Polished by z-tech. Stock type-r valves valves, Supertech Spring and retainers w/valve job. USED $750
Peak-Performance B-series vtec cams with Peak cam gears- Low miles looks to be less than 5000 miles put on them. USED $400
Specs on cams: Intake: Duration: 255° @ 0.05in Lift: .496in
Exhaust: Duration: 256° @ 0.05in Lift: .494in
Edelbrock Victor-X intake manifold for B16/B18c5 4764- Used Comes with Hondata gasket. USED $290
Skunk-2 throttle body- 70mm no tps or map. USED $160
BDL B-series fuel rail- bronze. USED $75
RC 310cc injectors- USED $245
Rage B-series Tri-y header-no dents not smashed on bottom great condition. USED $425 or $450 with Omni test pipe cut to replace cat.
Greddy sp2 for dc2- USED $200
Endyn B-series 81.5mm B18b Roller Wave pistons- N/A high compression compression/height 1.185 comes with pins and lock needs rings, needs rings under 5000 miles. USED $250
Eagle ls big bolt-Used $150
Hondata s100 comes with ecu from hondata- $250
Fluidampr- For B-series, street version-a/c p/s. USED $275
AEM fuel pressure reg.- Red $50
ARP-Ls/Vtec Head Studs USED $60
Moroso- Alumi 5.5 quart oil pan with ls pick up used $150
Drive Shaft Shop- B-series Old stage 3 axles don’t need hubs for these. $500 (rated at 600hp)
Hasport- B-series engine, tranny and back mount. Fits EG and DC2 $225
Fidanza-B series Flywheel 12lbs. USED $75
Exedy- B series flywheel 7lbs USED $120
Avid- Traction bars for EG and DC2 $250 USED
pm for details and pics
Aslo looking for Stock mounts, Stock oem axle,Stock exhaust
Johnsonn
Jun 18, 2017 07:27 PM
nacivicsi
Northwest (Sales)
16
Mar 5, 2012 07:08 PM
vaporboy12
Apr 28, 2009 06:32 PM
