new to civics. few questions help???
hey people i just bought my first 2001 honda civic ex and i love it so far but. when i was in my buddys 2002 civic ex i noticed that when he shifted gears in high rpms his tires chirpped and my dosnt. can it be that my car is on 18inch rims(came with car)? also my low beams dont come on(most of the time) so i have to drive with high-beams(but there not bright enough to be high beams). any suggestions? last of all i just got the lower control arm bushings replaced and it helped with front end handling but still on bumps or road faults the front end slip away, could it be the 18in rims and low profiles or something else. i also noticed this problem when in high rpms the front end goes all shifty?
i would appreciate any feedback/suggestions, thanks alot
well first off get rid of the 18 inch rims.. they r not good on our cars.. they r too heavy and u lose power.. second of all do u have aftermarket ebay healights??? or oem headlight?? evry other problem u have all direct to the huge rims u have.. go bak to stock size which is 15 inch.. then everything will b good
tragiclude-thanks. that is what i thought. and as far as headlights i think there the ebay aftermarkets. like i said i just bought this car its a older low budget show car. (first honda to get a wide body kit.)
one more thing since the car is a wide body, will 15's look to small
Well, in all honesty, it's probably going to look bad regardless since you said the words "low-budget" and "widebody kit" in the same sentence. If you want a good compromise between looks and performance, I'd go with 16" wheels. Tires aren't quite as prolific, but it's a good compromise.
And yeah, your car's performance is going to be adversely affected by the larger wheels. There's just more mass for the engine to spin around, and it doesn't have that much power to begin with.
Well, which do you want? A manual swap with forced induction, or a K-series engine swap?
I missed the Auto trans part.. OOOPPPPSSS but you could p/u a Z6, y7, ect tranny for dirt cheap and do a manual swap. but i guess if your gonna swap might as well make it worth while
Boosting and Swapping are both in the same ballpark, done right. Yeah, you can bitch-boost for less than a K-swap, but if you want a decent build, you'll wind up paying the same as if you'd swapped in a K-series motor.
Ok this is the deal..First of 18's are DEF NOT TO BIG...I have 18's on my car and its not a problem at all..The stock rims on the 04 ex are 15"...Dont be stupid bro...You take the 15" rim and the size of the tires...Than get your 18's with smaller tires to match the same size as stock. I have no problems what so ever with my rims and they look hot..Once I put on my lowering spring and struts its will be even more baller....And they make 18's that are light weight....so they dont slow me down...plus I am running 7.5 psi so doesn't matter much with the boost...
Well we talking auto or manual...B/c the Auto tranny can't handle much at all stock. If you want to boost a auto you will need to get a lot of tranny work done and wouldn't be worth it. Would be better to do the 5 speed swap. Currently I am running an exedy stage 2 clutch and Act lightweight flywheel. So the tranny can handle around 260 whp....but an auto you would be lucky to make it down the street running 7-10 psi...
