Suspension & Brakes Theory, alignment, spring rates....
92-95 civic and 94-97 teg supension
Old Dec 4, 2008 | 11:04 PM
E JAY 1's Avatar
Default 92-95 civic and 94-97 teg supension
they both fit the same correct..??
just makin sure cause i got some teg shocks and springs lying around and gonna put them to use due to my shocks being out and old coilovers that are rustin away..not good for winter time..so just let me know thanks...
Old Dec 4, 2008 | 11:31 PM
BlueIntegraBoy's Avatar
They're interchangeable
Old Dec 5, 2008 | 01:06 AM
E JAY 1's Avatar
so they will work with no problems..as in fit the same way and everything
Old Dec 5, 2008 | 04:24 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Yes they are 100% interchangable.
You do know they'll probably make the Civic sit like a 4x4 though, right?
Old Dec 5, 2008 | 06:44 AM
ShadowSkill's Avatar
B18C5-EH2 is correct. Is your car a coupe or hatch? The spring rates are different between the two chassis types. I know from personal experience that 92/95 USDM civic coupe suspension bolted up to a 92/95 USDM civic hatchback will jack your car almost 1.5 inches or more. I'm guessing that integra suspension will do the same to a civic coupe, assuming the spring rates are different due to a heavier motor.
Adjustable Coilovers however, are interchangeable.
Let us know if you try it.
Old Dec 5, 2008 | 08:57 AM
gsrpedro's Avatar
u can use the teggy shocks but the springs are gonna make the civc sits higher
Old Mar 24, 2012 | 07:47 PM
90HFCrX's Avatar
Default Re: 92-95 civic and 94-97 teg supension
can you use the dc struts and springs with the stock eg wishbone? i have the same quesition been looking for the answer but no luck
Old Mar 24, 2012 | 08:54 PM
redlinexd's Avatar
lol, I like how you made a post on a topic that was made about 4 years ago.
redlinexd's Avatar
and the answer to your question, yes.
VTEC_PRODUCTION
Sep 9, 2007 05:52 PM
SlowSOHC-T
Suspension & Brakes
Nov 3, 2005 02:30 PM
c.u.one
Apr 12, 2004 09:17 PM
Adriano
Nov 2, 2002 08:41 PM
Jmm0056
Jul 1, 2001 10:53 AM
