Hood problem
Old Dec 4, 2008 | 03:47 PM
90si-rex's Avatar
Default Hood problem
When I was doing my swap recently, I removed the hood to make removal and replacement of the motor much easier. I just reinstalled the hood tonight, and after I closed it, I noticed it wasn't sitting right. So I go to open it, and the hood release cable snapped. I'd been having trouble with it for a while, so it wasn't a big surprise. Now I'm stuck though. How in the hell can I get my hood open without a cable? Obviously I have to get the hood open to replace the cable, but how do I do this? If anyone has any ideas, I'd appreciate the help.
Old Dec 4, 2008 | 04:34 PM
88Hatchy's Avatar
see if you can get to the hood latch with the bumper removed
Old Dec 4, 2008 | 04:38 PM
90si-rex's Avatar
I was afraid someone was going to say that lol
Old Dec 4, 2008 | 04:48 PM
1fstrex's Avatar
First off where did your cable break at the latch under the hood or inside the car ?
Old Dec 4, 2008 | 04:49 PM
mauroalvarez@yahoo.com's Avatar
u can chain it up from the bottom if u wanna do it bootlegged.. but thats temporary until u take it to a bodyshop or dealership or mechanic to ge it fixed.. or u can gu for the REAL hood pins.. the ones that actually hook-up onto the car.
Old Dec 4, 2008 | 04:53 PM
1fstrex's Avatar
You cant pull your bumper cover off with the hood slammed shut , there are 4 bolts holding it on at the top under your closed hood .
Old Dec 4, 2008 | 05:07 PM
90si-rex's Avatar
I'm not 100% sure where it broke. I pulled the release lever inside the car, and rather than the hood popping, the cable just kept pulling, and eventually I had the lever and about 12" or so of cable hanging down inside the car. It was already dark, so I pretty much just said "ef it, I'll work on it tomorrow".
Old Dec 4, 2008 | 05:38 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Man I love honda-tech.
Yes you sure 100% can remove the front bumper off with the hood closed.
Here are the steps.
1 Remove the bumper turn signals
2 unbolt the bumper support from the frame ( two bolts inside the turn signal opening)
3 remove the 2 screws on each corner where the bumper meets the fender
4 remove 2 or so 10mm bolts at the bottom of the bumper ( under and behind the lip)
5 lift and pulll the bumper off the car.
Sorry, but you have to remove the bumper to open the hood.
Old Dec 4, 2008 | 05:54 PM
90si-rex's Avatar
Here are the steps.
Yeah, I knew you could remove the bumper with the hood closed. Done that about a dozen times give or take lol but I'm not in a flaming mood tonight so I was gonna let that slide. Guess I know what I'm doing this weekend......
Old Dec 4, 2008 | 06:04 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Click on this pic and it will show you how the mechanism works:
Hope that helps you..
Old Dec 4, 2008 | 06:51 PM
90si-rex's Avatar
That pic is actually incredibly helpful. It's actually more helpful than the diagrams in the manual.
Old Dec 4, 2008 | 07:05 PM
88DXCRX's Avatar
The time my hood stuck,
I got underneath with a long hook tool and managed
to hit it where it pivots and it popped for me..
It helps to already know what you can't see...
So I looked at my other car and figured out the "mechanics" of it..
soodominican
Dec 6, 2008 01:41 PM
boostedhks
Jul 24, 2008 07:45 PM
turboeg_4
Aug 29, 2005 05:51 PM
naterpatater77
Feb 29, 2004 05:32 PM
scrolanky
Jan 21, 2004 05:21 PM
