Again 94@98 gsr parts out another motor, trans front clip etc lots of new stuff. Lot
Lots of stuff everything is firm since i lost my job but will be negotiable to a certain extent.
Prefer not to ship the interior, trans, motor and front clip, since i also have no car.
94 and 98 teg stuff:
No pics of this:
95 gsr b18c1 motor missing dizzy, and wiring harness complete 1000 picked up no pics no shipping pm/email me to look at it.
95 gsr trans no grinds 500 picked up
anything off a 95 gsr teg lmk
p-72 timing cover set
comes with all bolts
top part was notched to allow you to pull cams out of motor with out pulling the timing cover set
Best offer shipped
gsr valve cover small nic was new before i left it upside down in my trunk and nicked the paint a little
Comes with new cam seal and valve cover gaskit also comes with gromets and the washers and nuts to hold it on, comes with the plug wire cover aswell
65 shipped
GSR p72 obd 1 new in the bag oil pump
**also have a new oem gsr strainer i can sell with it or separate and i have a new in the bag oem front main seal
New oem from honda with new oem front main seal
comes with new bolts
130 shipped
New b18 a,b,c (all use the same part number/rear main seal plate) oem rear main seal with plate
13 shipped
upper gsr coolant hose
13 shipped?
****B18 c1 cams
These cams came out of my gsr i am not 100% sure but they may be b17 gsr cams i dont think they are ctr/type r? i have to check with a micro meter to be sure
80 shipped
ls obd2 auto harness
dont need it came with motor
30 shipped nothing cut cept a wire for the trans
obd2 alternator
30 shipped
New gsr p-72 power steering pump
best offer shipped
good ac pump for b18
30 shipped
***b18b1 motor comes with no dizzy/alt/ac pump/power steering pump/wire harness
came from an auto car
motor is an obd2 but can easily be converted to obd 0,1,2.
Comes with everything else
had 95k on it before it was t boned.
450 picked up
94 GSR trans no lsd only grinds 3rd when you race the living **** out of it, you have to really try to get it to grind
550 picked up or can drive it to you for you to see and test before you buy it
No pics of this:
Best offer shipped
65 shipped
130 shipped
13 shipped
13 shipped?
****B18 c1 cams
80 shipped
obd2 alternator
30 shipped
best offer shipped
30 shipped
450 picked up
GSR usdm p-72 pistons 4 good pistons and 2 good rods
45 shipped for all
gsr p-72 water pump
30 shipped?
obd 1 gsr p-72 crank pulley
best offer
gsr p-72 timing tension
20 shipped
knock sensor for b series
60 shipped
B18 dizzys all in like new working condition non are hacked up:
obd2 ls dizzy approx 6k on it like new
50 shipped
obd 1 ls dizzy under 5k miles:
50 shipped
obd1 gsr p-72 dizzy unknown miles but looks to have some new parts one it With spark wires
125 shipped
obd0 ls dizzy unknown mileage on this new one
50 shipped
*****GSR clean **** and shift linkage
clean shape no pics
best offer shipped/picked up
GSR leather interior
Looking for pic up only
best offer for all of it
All mint cept driver seat has small tear
GSR cluster off a obd1 teg
best offer on it
45 shipped for all
gsr p-72 water pump
30 shipped?
best offer
20 shipped
60 shipped
50 shipped
50 shipped
125 shipped
50 shipped
clean shape no pics
best offer on it
98 front clip
700 picked up for complete front clip
Includes only the fenders, hood, 98 new headlights, 98 new amber turn signals and new 98 oem headlights
The headlights new for a 98 are 400 by themselves are brand new from honda!!! Bumper for a 98 new was 200 It was over 400 for just that alone for those 2 headlights, plus your getting the black hood and fenders, 98 ambers and bumper
EG stuff:
eg stuff
eg clock 15 shipped
hf mani 35 shipped
eg manual axels for driver side abs ring comes of so it can be made to use on a non abs car
30 picked up each
d series rear t bracket
15 shipped
eg corner lights 20 shipped for both
hf cat 35 shipped?
b18 half shaft came from an auto car its off a dc if some one can use it or the bearings out of the input lmk
Also if you can use an auto half shaft on a manual lmk
best offer shipped
EG stuff:
eg stuff
eg clock 15 shipped
hf mani 35 shipped
30 picked up each
15 shipped
hf cat 35 shipped?
best offer shipped
80 dolla crx hf
Dec 10, 2008 10:44 PM
